Key Turns No Start
I just drive my 87 c4 to walgreens with no issues, and when i went to leave, it wouldn’t start. Key turns and car powers up (battery voltage stays over 9 volts) and the engine makes no noise. There is a clicking sound coming from the dash though.
Im thinking it’s the VATs system failing or maybe an ignition switch issue?
I am in a hurry to fix it, as I daily drive it and go to work everyday. Autozone has an ignition switch that says it’ll fit , but I’m not sure if i believe it. If it will work as a temporary solution I’d be willing to do it anyhow.
Any information helps!
The SER (Starter Enable Relay) is in the center of dash! Do you have the FSM (Factory Service Manual) for your car? Ignition switch fits many GM's, I would expect it on their shelf BUT not likely a solution. See if you can reach under the dash and stroke the ignition rod to get CRANK - this would work if the rack & rod from ignition cylinder to the ignition switch had failed. I wouldn't expect click from dash if this were the issue.
It's called a 12v system for a reason
Yeah wouldn’t say I’m a car guy. Just bought this corvette at 19 with cash! Thought it would be a fun experience to learn from and create some cool stories. Appreciate all the love from you “car guys” though!
)Also make sure when you get it running that the alternator is charging the battery, you can take it to an autozone etc... to have them test but you should also be able to tell from the volt gauge, it should be reading around 14 volts or more when running.
OP Note: Some voltage drop during starter operation is normal as result of series resistance (battery, cables, connectors, etc) combined w/ high current. However, there is a minimum voltage required to keep the starter solenoid energized. And, when the solenoid switch completes the circuit to the starter windings, if the combination of the series resistance is too high, the voltage drop will cause the voltage to dip below that necessary to keep the solenoid activated - and the solenoid fails to hold the switch closed - and it "clicks" open. Then there is no current, thus no drop in voltage & immediately the 12+ volts returns and the solenoid once again latches the switch to the starter windings - only to have the voltage drop again below minimum for the solenoid to work. The on/off of the solenoid switch will cycle several times a second. Thus the clicking or "chatter".
One of the other less common (but significant) sources of voltage drops is the starter enable switch on the clutch pedal (assuming a standard trans). Remedies include replacing the switch, jumper across the switch contacts, or installing a auxiliary relay (usually behind the battery) to transfer the high current load from the clutch safety switch to the auxiliary relay instead.
