Reverse lockout ring sticking?
Old Dec 22, 2021 | 01:06 PM
meshies's Avatar
meshies
Default Reverse lockout ring sticking?
My ZF6 reverse lock out is getting very very hard to pull up. I sprayed some silicone down there and it helped for a little bit but now it is very hard to pull up again. I do not want to remove the lockout completely.
Has anyone ever had this? Any tips on how to fix this or what needs to be replaced? I looked through the FSM but couldn't find anything about service of the lockout mechanism.
edit : its not the ring itself, its the rod that is hard to pull up.
Old Dec 22, 2021 | 01:40 PM
WVZR-1's Avatar
WVZR-1
If the 'lift ring' is split or the female threads failing on the ring and set screw not securing the rod, you might interpret that as a 'rod issue' but in fact a lift ring. The GM # 10079757 is still available from dealers I believe or a 'reseller'. I'd start there. Have you removed the **** and actually inspected the ring? It's very easy I believe to strip the female threads of the ring.
Old Dec 22, 2021 | 05:42 PM
meshies's Avatar
meshies
Hmm the ring actually is slightly cracked where the threads are. You think that could be the culprit?
Old Dec 23, 2021 | 12:36 PM
Scott Rasmussen's Avatar
Scott Rasmussen
if its cracked you can over tighten the set screw which will cause the collar to split open just a bit which in turn means it wont hold the set screw tight against the rod. Happened to me. I have not glued or fixed the ring, I just dont tighten the set screw all the way. Trial and error a few times and you will find the sweet spot like I did.
Old Dec 23, 2021 | 06:09 PM
meshies's Avatar
meshies
interesting. It seems like there is excessive tension on the actual rod and it is hard to pull up, I cant figure out how a cracked ring would cause that.
To Reverse lockout ring sticking?
