bone jaring ride
Old Dec 26, 2002 | 05:05 PM
insanegt1's Avatar
insanegt1
Default bone jaring ride
Anyone got an idea why my 86 rides like a two ton truck??and what to do about it.
Old Dec 26, 2002 | 05:08 PM
Kale's Avatar
Kale
Default Re: bone jaring ride (insanegt1)
1) Because it's a sports car designed in the mid 80's with an awesome (but not docile) suspension and a somewhat "loose" frame.
2) Enjoy the ride! If your shocks are bad, your ride will firm up a bit by replacing them. Bilsteins for handling, but KYBs ride nice (although dont handle as well, but are cheaper.) Also check your tire pressure, maybe its too high?
Old Dec 26, 2002 | 06:28 PM
don hall's Avatar
don hall
Give us a hint as to your tire pressure, and the type of shocks you have installed.....
Old Dec 26, 2002 | 06:32 PM
GDP's Avatar
GDP
Could be springs or shocks going out.
Old Dec 26, 2002 | 11:08 PM
vader86's Avatar
vader86
If its Z51, then its supposed to.
Buy new shocks, yours are probably worn out. Bilsteins are good for a autocrosser and road handling. Edelbrock IAS and KYB for a softer ride, but realize youll lose some handling.
The leaf springs can also wear out over time, it may be time for a replacement. You can drop down to the base spring to soften things up instead of the Z51.
Also be sure that the tire pressure is around 32-35psi.
Old Dec 27, 2002 | 01:13 AM
NBM LS1 M6's Avatar
NBM LS1 M6
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19
If it's a Z51, enjoy the ride. Some of us want a Z51.
:D:confused::D
Old Dec 27, 2002 | 02:32 AM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default Re: bone jaring ride (NBM LS1 M6)
I love the feel of my 84 (non Z51). Handles like its on rails. My friends are always amazed how well it takes corners (one drives an SUV). Much fun Much Fun :cheers:
Old Dec 27, 2002 | 11:10 AM
insanegt1's Avatar
insanegt1
How do you tell if its a Z51??Do not have the builtsheet.
Old Dec 27, 2002 | 11:21 AM
Gary04Z06's Avatar
Gary04Z06
Look on the RPO sheet in the rear glove box, it should say Z51 if you have it. Also, the Z51 is 2 to 2 1/4 complete turns of the steering wheel. Z52 is 2 3/4 complete turns.
Sports cars ride rough, makes them handle better, if you want a soft ride, maybe trade it for a Caddy. :cheers:
Old Dec 27, 2002 | 04:56 PM
insanegt1's Avatar
insanegt1
Default Re: bone jaring ride (Gary96LT4)
When I say boan jaring I mean that every piece of plastic and trim is either broke or split. This vett has only 86000 on it and is in perfect condition. Springs and shocks are like new as well as the tires. I also own a caddy and a number of other sports cars. So I don't want another caddy just ideas.
Old Dec 27, 2002 | 10:23 PM
vader86's Avatar
vader86
Well there really isnt anything to do about it if the springs, shocks and tire pressure are all good as you say.
You can replace bushings, but they make little difference in comparison.
Drop down to the base suspension, and buy some cheapo shocks if you want it fixed. Otherwise deal with it.
Old Dec 27, 2002 | 10:32 PM
CowboyNVette's Avatar
CowboyNVette
Default Re: bone jaring ride (vader86)
You can lower your air pressure in your tires too. I have seen some lower to 28 lbs just to get a smoother ride, but you sacrifice tire life too that way. If you are running a lower tire pressure you will get more sidewall flex which in turn heats up the tire. The more heat you run in a tire the less tire life you will have so its up to you. :yesnod:
Your best bet is to buy some cheaper shocks but keep in mind , since you aren't wanting a autocross car, that you will lose some of that cornering on a rail sensation too. One thing will help, buy a newer C4...the 96 is supposed to have the softest ride. :lol:
[Modified by CowboyNVette, 9:33 PM 12/27/2002]
Old Dec 27, 2002 | 11:45 PM
Hamert's Avatar
Hamert
Default Re: bone jaring ride (CowboyNVette)
My ex's 85 with 59k on it handled nice and all, but every bump you went over the whole car rattled. Stuff inside, stuff outside, stuff underneath. She had a few broken pieces of plastic too. My 96 with 59k on it rides sweet. In fact, everyone I have taken in it for a spin has commented on well it rides for a sports car. Some of those same people rode in the 85 and they all said it was a rattle trap. Get a newer one I guess??? Oh yeah, no offense to you earlier year C4 owners. Driving the 85 is what made me want one, rattles and all. Besides, I don't know much about the history of that 85. It was definitely fun to drive! :thumbs: I am sure they made many small changes and improvements over the years, but my '96 has it's share of rattles too. I think every car has some squeaks and rattles somewhere or another. Good luck! :)
Oh yeah, post your VIN# and I'll give you all the options it has and let you know what warranty work was done to the car. :cheers:
[Modified by Hamert, 11:47 PM 12/27/2002]
Old Jan 2, 2003 | 12:25 AM
WAYWRONG's Avatar
WAYWRONG
Bone jaring is good you can not fall asleep at the wheel.
Old Jan 2, 2003 | 12:32 AM
November Soul's Avatar
November Soul
Look underneath for the extra braces.
Like this one I bent http://temp.corvetteforum.net/c4/nov...l/bent_bar.jpg
Old Jan 3, 2003 | 09:44 AM
drvette85's Avatar
drvette85
I still remember purchasing my 85. I had sore kidneys for a couple months!!!
But ... I wouldn't give up this bone jarring ride for nothing!!!
:seeya
Old Jan 3, 2003 | 12:52 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
If you want a soft ride.....install new springs and shocks from VetteBrakes. They will fix you up......just tell them what you want. :yesnod: :cheers:
Old Jan 3, 2003 | 01:25 PM
Torch Red's Avatar
Torch Red
St. Jude Donor '09
Although not the same year, etc. I had specifically serched for (and obviously found) that Z51 option in the 96 (shown in my current sig) It absolutely rides differently then the base as well as select-a-ride but it was what I deliberately wanted in this particular purchase for my collection.
Yes some people have commented it is not a soft ride, etc.
The RPO decal in the cubby hole lid told me what I wanted to know. Z51
To bone jaring ride
