LT5 and optispark
Old Jan 13, 2022 | 01:57 PM
MisterC's Avatar
MisterC
Default LT5 and optispark
I'm developing an interest in buying a C4 ZR1. Does the Lotus built engine have the same optispark issues as the LT4? Thanks.
Old Jan 13, 2022 | 02:08 PM
mrlmd's Avatar
mrlmd
No Optispark, completely different engine.
Old Jan 13, 2022 | 02:11 PM
vader86's Avatar
vader86
Nope, totally different.
Old Jan 14, 2022 | 08:31 AM
SJW's Avatar
SJW
LT5 ignition is a distributorless system.
Live well,
SJW
Old Jan 16, 2022 | 07:00 PM
Paul Workman's Avatar
Paul Workman
As said, it is totally different: a entirely digital ignition system (DIS) module bolted to the under side of the plenum, which is controlled by the ECU. The coils (4) are located under the plenum as well; each firing two plugs each in a "wasted spark" arrangement (think of a loop from the coil to a spark plug, through the block, back through a second spark plug before returning to the coil. [proven to be extremely reliable])
To LT5 and optispark
