while driving just shut off?
Old Jan 16, 2022 | 04:29 PM
InfaredMustard's Avatar
InfaredMustard
3rd Gear
Default while driving just shut off?
so I just bought a 1988 corvette base, just installed a new clutch master and clutch slave cylinder let the car warm up and we took it out for a drive temps and everything was fine running great. The overdrive was being a little funky but nothing concerning then we are approaching a stop light and it just shuts off like power and everything. The battery was stone dead to note before we took it so we had to jump it to get it running when it shut off I hooked a jump pack up to it again and all lights went on dash and all but no click no crank was stone dead any ideas on even where to start getting a new battery tomorrow? thank you for your time.
InfaredMustard
3rd Gear
to add last summer owner has receipts had plugs wires rotor and cap done.
Old Jan 16, 2022 | 04:47 PM
DWAVette's Avatar
DWAVette
Did you verify your charging system is working? Maybe you were running on a weak battery until it finally drained.
Old Jan 16, 2022 | 07:51 PM
ls777z's Avatar
ls777z
Old Jan 16, 2022 | 07:59 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
We can all WAG it....or you can grab a meter and see for your self.
Old Jan 17, 2022 | 02:43 AM
topfuel67's Avatar
topfuel67
Common issue on any car that is this old. Clean all electrical connections. Grounds, plug connections, both sides of battery and cables. Clean the connections to the PCM, everything. There's electrical sprays that will help clean plug connectors that you can't get a wire brush into.
Old Jan 17, 2022 | 09:26 AM
Incorvettei's Avatar
Incorvettei
Get it running and look at the output from the alternator. My thoughts are that your battery is getting nothing back from the alternator so it just drains the battery.
Old Jul 17, 2022 | 04:27 PM
InfaredMustard
3rd Gear
you guys were right was a battery thanks for the help
To while driving just shut off?
