so on the ongoing project which is my '84 C4, I found that I was getting a lot of water in my fuel. We pulled the rear fuel cover and found the sending unit had rusted just about 3/4 of the way around. I then started to try to get the bolts out. "bink" Well crap, bolt broke the head off. start the soak using everything I had, Deep Kreep, Kriloil, Penetrating oil. I kept applying for 3 days. tried to remove using light rocking, "bink", "bink". Ok S*&ew it, get he Makita Impact and just snap them all off.
So now here we are. Has anyone done anything like this or info on how to get the rusted remnants of bolts out of the tank so I can replace the sending unit.
Thanks in advance
Displace all of the fuel and fuel vapors with something; water, inert gas...whatever you have handy.
I assume they broke off flush with the top of tank? If there is some sticking out, grab 'em w/Vise grips, then heat the nut w/a torch, thread 'em out.
If broken flush or in the hole, I'd drill out the old nuts entirely, weld in new ones.
Tom's way probably is the best way to go about it, absent replacing the tank itself.
For anyone who does decide to replace their tank for whatever reason, I will say that it took me almost two weeks to do it. But it was also my first attempt at doing it, so it was kind of on and off job.
After the first time doing it, I'd say you could probably do it in a day/day and a half with a helper where needed if you start early. Just be sure to have new hardware and straps before jumping on it.
Like most every other pain in the rear end job it's usually much, much smoother going the second time around. Though I don't foresee having to ever do it again in my lifetime.
Food for thought: If the sender bolts all snapped off, how easy are the bumper fasteners going to be to deal with? (They're likely to be just as corroded as the tank hardware).
I had not thought about this but it's an excellent point. And you can't heat those nuts.
I haven't looked at a C4 tank for years. I may be wrong. The 'threads' may be blind inserts welded to a metal ring that is secured inside the tank, probably with spot welds, possibly with rivets that are under the perimeter of the sender flange. The threaded holes are going to be blind to prevent a leak path for both liquid and vapor by the threads.
Could it be possible to find and drill out the spot welds (rivets) remove the ring and renew the threaded bungs? Or go to nuts, Or something. It would be worth a cleaning of the flange surface to inspect for the attachment method, and conduct a close visual inspection regarding feasibility of implementing this idea. If the interior of the tank is serviceable, this could save a lot of work by not having to do a tank R&R.
I ain't looked either but I'd think they're likely 'rivet nuts' OR 'rivet nuts' could work and being such a small diameter they would be quite easy to replace with a hand operated device. If there's a commercial body repair facility in the area they would likely have a pneumatic tool that would do the installs.
The OP having an '84 it's certainly advisable to attempt something other than tank replacement if practical I'd think!
Dealing with the same issue on my 84. The ring that has the threaded holes is underneath the tank liner and not accessible. Drilling out and inserting rivnuts might be an option. I had also thought about drilling all the way into the tank and inserting bolts from the other side and welding, but that risks compromising the liner. Aftermarket replacements are a bit hard to come by right now, most places have no eta on when they will have stock.
