I have a "Low Coolant Level" warning light on in my 1990 C4 (L98). I assume that it is a float sticking in sensor, which I believe is in the high coolant tank (upper R/S of firewall). Plan was to drain and remove the tank and then clean it out, hoping to free-up the sticking float. I can't even get the damn cap off the tank. It appears to be a standard 17# radiator cap. The arrow is aligned with the vent tube when closed. I can turn the cap about 30 degrees counter clockwise, to the point that it pops-up, but it won't come free of the neck of the tank. Is there a trick? Is the cap defective? Am I just too weak at my advanced age? This project got halted before it ever got off the ground - HELP?!?
I thought I had, but apparently not hard enough. Put some weight behind it this time and it came off. Thanks. Tank is drained. Top two vent hoses are off and having a hell of a time getting the two bottom hoses (with spring clamps off). Also can't figure out the release for the electrical connector for the sensor. But we will prevail. Thanks for the helping me past my stupidity.
Removing a hose that's been clamped in place for 30 years is frequently "problematic".
rocco16's suggestion to use a hair dryer is certainly worth a shot. (I assume that you were able to get the spring clamp "off".) Many pros use a pick with a 180 degree bend in it that will get between the hose and the fitting and free it up a little bit at a time (see link below). I've had some luck twisting the hose to break it free - using channelocks - but that can break the hose barb on the tank if the hose is really seized. I'm not sure about the L98 hose routing - but you could also look at disconnecting the other end of the hose...
Mission accomplished....almost. I went out and bought a pair of locking spring-clamp pliers. Still not easy, but much better than any of the alternative methods I was trying. Hoses really didn't present a problem and once the tank was free of the hoses, it was easy to see the release for the electrical connector for the sensor.
Shook the tank and there was no rattle at all, so the float was stuck. Used hot water and dish detergent, agitated and drained a number of times. Did get a fair amount of crud out of there and the best part, after the wash/rinse/repeat, was that now I could hear the float rattle when I shook the tank. Paydirt. I let the tank dry overnight and today put everything back together (much easier than coming apart).
With great anticipation, I fired it up. Mmmmm, light is still on. Take it for a drive and let it come up to temperature - still on. Does this need to be reset? Is there a reset procedure? I'm right back to square one.
I bought a pair of Craftsman remote hose clamp pliers. Sometimes you don't have enough room for the pliers and the remote clamp tool works great. It certainly has saved me some grief over the years.
Don't know if this is any help, but I had a persistent Low Coolant warning on my '88 following a radiator flush. After 'burping' the coolant system a couple of times all was fixed. It seems that there can be airlocks that cause the problem (in my case).
I'm having the same problem with low coolant warning coming on after replacing my radiator and heater control valve, it comes on when the thermostat opens at 180~190
I burped it maybe 5-7 times but light comes on right after the thermostat opens. I have new coolant switch sensor I even checked for leaks using radiator pressure tester
still no luck. Also I replaced the radiator cap with 16PSI cap.
