C4 Sun Visors
Old Jan 27, 2022 | 10:22 PM
Desert Rider's Avatar
Desert Rider
Default C4 Sun Visors
1996 C4; my 1st Corvette. What's the solution to floppy/droopy outside ends on the sun visors? Thx
Old Jan 28, 2022 | 09:14 AM
GRIS's Avatar
GRIS
Took mine to Salvador the upholstery man. He cut off the flops and sewed up ends. No more problem.
Old Jan 28, 2022 | 09:30 AM
BillDurant's Avatar
BillDurant
I took both of mine off right after I bought the car, wear sun glasses
Old Jan 28, 2022 | 11:07 AM
jrobin1's Avatar
jrobin1
I opened up the floppy end, inserted a stiff piece of cardboard, glued it in place, restitched the cover. Worked fine. BTW, there are some you tube videos on how to repair these.
Old Jan 28, 2022 | 11:17 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I made, an old vertical blind I found someone thrown away.
I cut it the length I needed, and the light assembly lift it out enough to slide the vertical inside right to the end.
Then pressed the light assembly back in place and now the floppy end is spring loaded straight.
I fixed that, and it another ten years when I sold the car sun visors still looked great.
You can see nice and straight and the cost $000.00.
Old Jan 28, 2022 | 06:44 PM
glenx122's Avatar
glenx122
Ecklers Corvette sells repros.
I have them on my car. They look good work nice and are easy to replace.
Old Jan 29, 2022 | 11:20 AM
Desert Rider
Gr8 suggestions...THX!
Old Jan 30, 2022 | 09:11 AM
dizwiz24's Avatar
dizwiz24
Remove those chintzy, rattly SOB’
i did this on my 93 vert and couldnt have been happier.
makes the car feel more roomy with better view
be sure you have a pair of sunglasses in there
Old Feb 3, 2022 | 07:59 PM
krackenvette's Avatar
krackenvette
After 1st set was redone, I finally took mine out.. So much better..
But, If you can get them done in leather, with plastic on this inside, it would be nice.
I did my removable top in leather, instead of that cheap fabric GM used.
To C4 Sun Visors
