code for 86 gray paint
Old Dec 29, 2002 | 12:11 AM
hngacurv's Avatar
hngacurv
Default code for 86 gray paint
Does anyone know of the code for the gray bottom on an 86 silver/gray coupe? I'm thinking of buying a spray from the dealer to touch up on the bottom side of my front end. No, I'm not going to try and paint the entire gray area around the car if someone is thinking it. I'm getting the entire car painted sometime next summer, but would like to touch up some now.
[Modified by castivers, 12:12 AM 12/29/2002]
Old Dec 30, 2002 | 07:28 PM
hngacurv's Avatar
hngacurv
Default Re: code for 86 gray paint (castivers)
Anybody?
Old Dec 31, 2002 | 10:53 AM
c4cruiser's Avatar
c4cruiser
The paint codes should be at the very bottom of your RPO sticker. Check this link for paint RPO codes: http://www.corvetteactioncenter.com/...o/8496rpo.html
From the codes, it sounds like RPO 18L Medium Gray Metallic secondary (lower) exterior
There should be a pair of values that say WAxxxx and a "U" (upper) and "L" (lower). Any paint shop can get the correct codes from that. Also, auto paint stores can probably make a 16oz spray can for you. Around here these cans run about $20.
Hope this helps!
Old Jan 14, 2003 | 12:27 AM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: code for 86 gray paint (c4cruiser)
Go to http://www.paintscratch.com If it is a medium gray metallic, the code is WA7719.
Good luck!
To code for 86 gray paint
