Opti doctor update
I'm glad he rebuilt mine and I found a NOS opti ( i was going to sell, but not now
Popular Reply
some info, like I just replaced parts (X,Y,Z) and it did not solve my issues with
(starting, stalling, rough idle, how it runs, cooling, the brakes, transmission shifting, or the lack of power at (X) rpm etc,
the guys are frustrated as they spent time and cash but the issues is not resolved!
the "PROBLEM" is most people won't take the time or effort to diagnose a problem by logically isolating and testing each component before the parts are replaced,
and yeah its basically a two step problem, that having a SHOP MANUAL, for your particular year corvette ,
and a few basic tools like a FUEL PRESSURE GAUGE,MULTI METER, AND TIMING LIGHT, COMPRESSION TESTER,
and a CODE READER MAKE FAR EASIER, ISOLATE AND TEST ARE THE BASICS OF ANY REPAIR PROCESS>
you first have to understand how each component functions and how to test its functioning correctly.
it helps a great deal if you know the basics and have access to the tools required to test.
it helps a great deal if you understand how the various sub systems like ignition,
timing and terms like AMPS. VOLTS,RESISTANCE, and fuel delivery work, terms LIKE PRESSURE, VOLUME, and the basic 4 cycle engines design parameters.
theres not a single problem on a C4 CORVETTE, that can't be diagnosed with a shop manual, fuel pressure gauge, multi meter, exhaust back pressure gauge/vacuum gauge and an accurate infrared temp gun, timing light, compression/leak down tester, basic mechanics tools, a set of jack stands and a floor jack.
and a logical isolate and test mentality, if you have access to the internet to ask questions about related tests, PROVIDED you ask the correct questions and test to find the related answers,
yeah, having experience helps and tools like code scanners, degree wheels, dial indicators , a dial caliper, feeler gauges certainly help,
but you can solve problems by simply understanding how components are supposed to work, and how they can be tested to verify they are defective or not!
before you start spending cash, verify the problems source and yeah,
it helps if you have a knowledgeable mentor and some decent tools and a place to work.
and yeah, you could easily spend several thousand dollars on unneeded parts, or labor costs,
at the local dealership ignoring this advice! knowing how your car is supposed to work and how to test the individual components may take time and effort but it will save you a great deal of cash and wasted time .
and yeah, I'm all too well aware many guys find it far easier to spend cash rather than read links and think,
but you might be amazed at how much you could learn reading links and sub links
related info
http://garage.grumpysperformance.com...le-codes.2697/
http://garage.grumpysperformance.com...51/#post-88488
http://garage.grumpysperformance.com...26/#post-48779
http://garage.grumpysperformance.com...nd-here.12892/
http://garage.grumpysperformance.com...81/#post-56489
http://garage.grumpysperformance.com...t1-vette.1401/
http://garage.grumpysperformance.com...28/#post-93194
http://garage.grumpysperformance.com...28/#post-75647
http://garage.grumpysperformance.com...car-safety.26/
https://www.testequipmentdepot.com/e...ech%20Products
related info
Basically your blue piece that's rubbed through is a check valve, only letting suction go through one way (towards vacuum source....engine). You should be able to come up with a work around, something similar for HVAC systems (heater control vacuum like on a C3 Corvette) or cruise control systems that are vacuum operated. I will do some brainstorming, the ones I'm thinking of are black and white, finding a blue one will tough unless you get it from another corvette....but don't forget '95-'96 F-bodies (camaro, firebird/trans am) with an LT1 will have these, as well as any LT1 engine from '95-'96 in Buicks, Cadillacs, Caprices and Impalas. Either start scouring some good wrecking yards or find a good parts counter guy who will actually open up a Standard Ignition Catalog (good place to start, not a computer screen) and start going through the 'emissions controls' section and/or HVAC section and start looking at pics/descriptions until you find a suitable replacement (physical size, nipple size, etc). That's what I got for you, at least it's a starting point and once you have a part# shouldn't cost anymore than $3-$10! Good luck👍
edit: upon further examination of your picture, you could try a dab of 'Right Stuff' gasket maker, or since you can see how thick the blue plastic is, take a soldering iron and melt/work a little bit of the plastic from edge of burn through spot down to your low spot and melt it shut....then test it with a vacuum pump/gauge and see if holds (I bet it would), you could then put your "bad spot towards the engine, so you can't see it! It looks like you barely rubbed through to the internals, this would possibly resolve your issue and in the meantime you could find a replacement....be mindful of the direction of flow when you reinstall it!
