Vacuum lines
Old Feb 16, 2022 | 06:33 PM
controlu's Avatar
controlu
Default Vacuum lines
I have removed all of the ERG, A/C, heater coil, air pump etc. from my 1987 C4. I have had the ECM programmed to eliminate these items, along with VATS. I need to know what items under the hood are absolutely necessary to have vacuum lines attached to them for the motor to run as just a bare engine. I know the fuel pressure regulator needs vacuum, I’ll need it for the brake booster and for cruise control, but anything else I’m missing? I know all the under-dash stuff will need it but I’ll get to that later. Right now I just want to get this thing smooth idle, running and on the road and moving, stopping etc. Thank you for any replies, I’m in a dark area here re. vacuum systems.
