Dumb question
Old Feb 21, 2022 | 10:38 AM
amps1956's Avatar
amps1956
Default Dumb question
87 plain Jane coupe i guess you call them 350 tuned port. Tune port is gone but motor is good I know nothing about these is it worth up grading the power not sure what mains or compression is on these I have a bunch of small blocks but like to use the original if I can but know nothing about vette insides I guess you can say what is your opinion???
Old Feb 21, 2022 | 07:19 PM
Incorvettei's Avatar
Incorvettei
If the TPI is gone and it were my car I would probably switch over to carburetor and new intake. The L98 engine is generally a 2 bolt mains.
Old Feb 21, 2022 | 09:09 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
You have a standard Gen I small block and can treat it accordingly.
Old Feb 22, 2022 | 05:03 PM
amps1956's Avatar
amps1956
thanks that is why I asked I want to put a tunnel ram on it with 2 390s just basically for looks I am not racing but I don't know what cam it has or should I upgrade to little more it runs I started it with a carb and fuel regulator didn't smoke but I may pull and do a ring job just cause
Old Feb 26, 2022 | 03:53 PM
amps1956's Avatar
amps1956
ok update i have 85 not 87 and my carbs appear to be 450s also thinking about running e85 at least some to boost know nothing about what is in these motors any help on specs
To Dumb question
