I need to replace the injectors in my 86 vette. They currently have the stock 10108481 injectors which I thought would be easy to find however it seems to be a minefield trying to find the correct ones. Can anybody out there suggest a suitable replacement to the original AC Delco parts? I have seen a number of threads but there doesn't seem to be a conclusion.
You're likely to be better off with 24 lb/hr injectors anyway (without any tuning) due to the ethanol content of today's fuel since E10 requires about 4% enrichment compared with straight gasoline. If you're tuning, you can use any injector that you want and dial them in accordingly.
