Help
Old Mar 11, 2022 | 03:17 PM
GaryInArizona's Avatar
GaryInArizona
Default Help
Can anyone please tell me where the Starter Relay module for 87 is located?
Old Mar 11, 2022 | 03:32 PM
WVZR-1's Avatar
WVZR-1
https://www.corvetteforum.com/forums...-location.html
Now if you might have meant VATS Control Module that's a different 'component' so ........................................ ..
Old Mar 11, 2022 | 04:02 PM
GaryInArizona
I lost my key. Locksmith wants $600 to come to my house. I am looking at buying a VATS Delete Chip. They are telling me to find the Starter Relay and bypss it by jumping pin 87 and 30. How do I do that?? Any help is appreciated. Thanks
Old Mar 11, 2022 | 05:06 PM
GaryInArizona
They are telling me to find the Starter Relay in the under hood fuse box. Where is it located?
Once I find it I am suppose to pull it out of socket and on the bottom will be four numbers: 30, 87, 85, 86.
Then I am suppose to take a piece of 12 gage wire and jump 30 to 87 where relay plugs into fuse box.
I can't find the under hood fuse box???
Old Mar 11, 2022 | 05:53 PM
WVZR-1's Avatar
WVZR-1
Ain't one!
Old Mar 11, 2022 | 11:40 PM
jv9999's Avatar
jv9999
"They" don't know what they are talking about. You can bypass the starter relay behind the info panel (jump the two heavy gauge wires) which will allow it to turn over, but VATS will keep the injectors from firing.
Old Mar 12, 2022 | 11:24 AM
GaryInArizona
Can you please tell me which two wires I need to jump??
Old Mar 12, 2022 | 12:08 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
A to E, but the heavy gauge green/white in cavity A to either of the yellow wires C or E will work
Old Mar 12, 2022 | 12:38 PM
WVZR-1's Avatar
WVZR-1
It might be very wise to actually confirm that VATS is still active by checking the wire down the column to it's connector. Much depends on what you find!
You lost key OR this is a recent buy of a C4 with 'no keys'!!
Old Mar 12, 2022 | 04:14 PM
GaryInArizona
Thanks so much Ray Quayle. Appreciate the info.
To Help
