Missing connection on radiator?
Old Mar 26, 2022 | 12:33 PM
jschmidt's Avatar
jschmidt
Default Missing connection on radiator?
What is this missing connection on the radiator? This C4 is relatively new to me and didn't notice this when I bought it. Everything runs fine, was checking the radiator fluid and saw this.
What is the missing connection for?
Old Mar 26, 2022 | 01:38 PM
Deepa's Avatar
Deepa
Is your car a manual trans?
Looks like the fittings for the auto trans cooler lines
Old Mar 26, 2022 | 01:40 PM
ls777z's Avatar
ls777z
Old Mar 26, 2022 | 01:47 PM
jschmidt's Avatar
jschmidt
It is indeed. Small sigh of relief 😃. Should I have a plug there instead?
Old Mar 26, 2022 | 02:13 PM
ajp01's Avatar
ajp01
Nice to have a plug but not critical. That top fitting is matched by a lower fitting on the same side of the radiator. It's the automatic transmission cooler as Deepa said - not used on your car - and they usually (but not always) have a plastic plug over the threaded opening. Check to see if your lower one has a plug on it also.
Old Mar 26, 2022 | 07:12 PM
383vett's Avatar
383vett
Don't the 4+3s use the radiator for cooling the od?
Old Mar 26, 2022 | 07:51 PM
arbee's Avatar
arbee
Assume so but the OP's is an '89
Old Mar 26, 2022 | 08:47 PM
Mixednuttz's Avatar
Mixednuttz
2023 Corvette of the Year Finalist - Modified
2022 C4 of the Year Winner - Modified
Finalist 2020 C4 of the Year - Modified
They do. I'm 99% certain the radiators are the same for both the auto and manual in the early cars. (Unrelated note: I am looking forward to ditching those OD cooler lines in my 85 once I switch to a ZF.) I would just get some plugs if it really bothers OP.
Old Mar 26, 2022 | 09:36 PM
Bfenty's Avatar
Bfenty
2017 C4 of Year Finalist
Originally Posted by 383vett;[url=tel:1604920446
1604920446[/url]]Don't the 4+3s use the radiator for cooling the od?
you’re right but the ‘89 switched to the six speed so no auto trans. Makes sense that they re used the radiator though since most of the rest of the car is the same.
Old Mar 27, 2022 | 02:40 PM
Kilobuck84's Avatar
Kilobuck84
Maybe it would make a nice power steering cooler.
To Missing connection on radiator?
