How do I remove the Oil Pan?
Old Mar 29, 2022 | 11:05 PM
Cornhusker's Avatar
Cornhusker
Default How do I remove the Oil Pan?
Didn’t realize it until this evening that my 89 has a one piece oil pan gasket, or at least looks like it does. I have a new pan gasket & need to remove the pan. I removed the bolt to one motor mount but still can’t raise the motor enough to drop the pan. The timing cover is off & I’m ready to put it back on but pan 1st.
It looks like I need to pull the other motor mount bolt to lift the engine more. However do I also need to remove the two cross braces that meet at the front of the oil pan?
Thanks guys!
Old Mar 29, 2022 | 11:15 PM
383vett's Avatar
383vett
Rotate the motor to #4 tdc and try it.
Old Mar 30, 2022 | 11:10 AM
Cornhusker's Avatar
Cornhusker
Looks to me like the front main cap is what’s blocking me from pulling the pan. Then again, so is the other cross brace I need to remove on the drivers side and even the steel line, brake I assume.
Probably still need to lift the engine.
Old Mar 30, 2022 | 02:25 PM
MrBigDee's Avatar
MrBigDee
I have 86 and when I took the oil pan off I rotate the engine a bit and the bottom immediately dropped. I did not touch the engine mounts.
Old Mar 30, 2022 | 03:41 PM
ajp01's Avatar
ajp01
It will come off - hope this helps...from my 1989 as well, manual gearbox...
https://www.corvetteforum.com/forums...post1604563042
Old Mar 30, 2022 | 04:25 PM
Cornhusker's Avatar
Cornhusker
I lifted the engine some & the pan finally came off. I had removed the passenger side angled support but not the left. Nor had I removed the brake line, which would have helped. Since I already had the motor mount disconnect it was easy to raise.
The only thing hard to get off now is the very back of the pan gasket. I am assuming it’s RTV that is holding on like crazy but wanted to confirm before I pulled like hell!
Old Mar 30, 2022 | 07:50 PM
383vett's Avatar
383vett
The brake line does not run along the oil pan. You must be referring to the transmission cooling line.
Old Mar 30, 2022 | 10:10 PM
ajp01's Avatar
ajp01
It is very likely RTV. That is not the original oil pan gasket BTW, someone has been in there before....
Old Mar 31, 2022 | 12:01 AM
jazfe's Avatar
jazfe
I pulled mine today for a oil pump replacement. Removed both of the cross braces, turned the engine to #4 cylinder to top dead center, pulled the starter and removed all of the oil pan bolts and the pan dropped right out. No need to raise the engine. I have a 86 4+3.
Old Mar 31, 2022 | 04:18 PM
Cornhusker's Avatar
Cornhusker
This is the Brake Line that goes in front of the oil pan.
To How do I remove the Oil Pan?
