C-beam install ‘84 Vette
Old Apr 25, 2022 | 09:21 PM
MightyC484's Avatar
MightyC484
2nd Gear
Default C-beam install ‘84 Vette
I’ve been trying to re-install the c-beam for the past 3 days. I’ve read everything I could find to try and find something that works, but nothing has worked. I’ve tried everything. Is there any tricks I don’t know about? Any help is GREATLY appreciated!!
Old Apr 26, 2022 | 04:02 AM
Armybyrd21's Avatar
Armybyrd21
I’ve done this more times than I can count and it still sucks every time. Install on the diff first and use a pry bar to get the rest in place. You’ll have to play around with it and move the trans around til she goes. I also trimmed part of mine to help with install.
Old Apr 26, 2022 | 11:32 AM
Phobos84's Avatar
Phobos84
What part are you stuck on? Do you have the C beam in place and can't get the bolts lined up? I use a solid bar with a tapered end and pound it through the hole where one bolt would go. Then I put the other bolt in and get the nut on. It also helps to grind the end of the bolt a little to shape it like a bullet. Once you get one bolt in remove the bar and pound the second bolt through.
Old Apr 26, 2022 | 03:41 PM
MightyC484's Avatar
MightyC484
2nd Gear
Im stuck on trying to get the c-beam to line up. I can’t get the bolt holes lined up and I’ve tried everything. Brute force, dropping the tranny a bit lower, trying to level everything. Nothing lines up.
Old Apr 26, 2022 | 03:50 PM
383vett's Avatar
383vett
Raise or lower the back of the tranny. Raise or lower the nose of the differential.
Old Apr 27, 2022 | 12:03 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Pretty sure that's what I did. Might have been a large punch?
To C-beam install ‘84 Vette
