radiator removal
Old Jan 1, 2003 | 04:01 PM
legs's Avatar
legs
Default radiator removal
can anyone tell me the easiest way to remove the six lower screws on the fan shroud, and then the trick of getting them back in?
ps. a while back i was on here talking about a vats problem and got a lot of great advice on where the unit was. however, as it turned out it wasn't the vats system after all, it was the starter.
Old Jan 1, 2003 | 04:18 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: radiator removal (legs)
I didn't read thru all this, but this is from the tech tips section
https://www.corvetteforum.com/techti...D=53&TopicID=2
Old Jan 1, 2003 | 09:53 PM
Topload's Avatar
Topload
I've just finished doing this on my '94. I could reach the 3 on the passenger side without much difficulty using a 1/4 drive ratchet, socket and extension. The very top one I removed with a small box end wrench.
The 3 on the drivers side were a bit tougher. I removed the AIR pump assembly and used the box end wrench and a lot of patience. When I re-assembled the shroud, I pulled the clips off and turned them around so that they are now mounted on the frame pieces opposite the shroud. The screws are now mounted from inside the A/C condenser access - it made the re-assembly a little easier but it still took a bit of patience.
Good luck.
:seeya
Old Jan 1, 2003 | 10:52 PM
Charlutz's Avatar
Charlutz
Default Re: radiator removal (Mr Mojo)
:iagree: I did mine this past summer following the instructions in the tech tip. Worked like a charm.
To radiator removal
