More coolant system issues
Old May 23, 2022 | 09:17 PM
CorvetteRules's Avatar
CorvetteRules
The fan in my 95 comes on at 228-229 and temp drops quickly once on. Sounds like you got everything working as it should.
Old May 23, 2022 | 10:40 PM
TheKodiak's Avatar
TheKodiak
Originally Posted by Mike J Youngquist
Ok. The coolant is retaining pressure with the new radiator cap. And I discovered by reluctantly letting it idle for awhile that the fan will kick on when it reaches 227 degrees. I just never let it get that hot. Only found a leak in the upper radiator hose and replaced that.
Awesome!!!
