GS picture request
Old May 20, 2022 | 05:20 PM
BMH95's Avatar
BMH95
Default GS picture request
Need some detailed pictures, I’m hoping someone with a real GS can help with.
Did the factory fender flares on the coupes, exactly match the wheel well fender curve?
can somebody take a few pictures looking up toward the bottom of the fender flare to see exactly what the flare / wheel well edge of the quart looks like? A couple of close angles should do it.
this is a very important, as you’ll be solving a very contested debate with a case of beer on the line!!
thanks in advance…
Old May 20, 2022 | 07:21 PM
Vetteblack-96's Avatar
Vetteblack-96
Do they even sell beer in "cases" any more?
Old May 20, 2022 | 08:45 PM
BMH95's Avatar
BMH95
natty light!!
Old May 20, 2022 | 08:47 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
I know, but don't drink beer. ever.
Old May 20, 2022 | 09:29 PM
BMH95's Avatar
BMH95
whatever your poison - just send pictures!!
Old May 20, 2022 | 09:49 PM
*89x2*'s Avatar
*89x2*
Maybe @Bluewasp can snap a few.
Old May 20, 2022 | 10:51 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Not sure what he’s asking. I’m a little slow with my extreme old age.
the GS fender flare are bolted through the fiber glass. And the curve matches the curve of the wheel well. I cut mine out a little because I was running 335s in the rear. They rubbed but I figured what the hell cut that **** if gm already drilled holes through the panels
Old May 20, 2022 | 10:54 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
What is your definition of “exactly”? This is a GM a product so “exactly” is a no. I would say yes however if you look inside there is a slight lip from the shape of the quarter panel to where the flare sits. I cut this lip out
Old May 20, 2022 | 10:59 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Factory flare installed in 1996. You can see my grinding job. But if you look up you will see blue fender equal to the flare Does this help?
Old May 20, 2022 | 11:00 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
It’s hard to get photos when the tire is almost touching the body work. My car is lowered too
Old May 20, 2022 | 11:02 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Another angle…Left to right: Inner plastic liner, SMC fiberglass body, and then flare
Old May 20, 2022 | 11:05 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
More of the grind work.
Old May 20, 2022 | 11:07 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Old May 20, 2022 | 11:10 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Old May 21, 2022 | 11:23 AM
pedricd's Avatar
pedricd
Originally Posted by bluewasp
wow.
Old May 21, 2022 | 12:23 PM
BMH95's Avatar
BMH95
interesting - so you ground the fender up to be even with the flare?
thank you for taking the pictures!!
Old May 21, 2022 | 12:25 PM
*89x2*'s Avatar
*89x2*
Send @Bluewasp a gift card to Dixie Bones.
He’s come through for you, as I figured
To GS picture request
Old May 21, 2022 | 12:45 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
no. I grounded it down because of the 335 tires. So when you hit a bump the tire goes up and in, an arc, so I had to cut a couple millimeters out of the flare and and the outer quarter you would normally see with out the flare
but yes I would consider the flare to follow the contours of the quarter panel. Again. This is an assembly line vehicle
Old May 21, 2022 | 12:46 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Old May 21, 2022 | 12:52 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
