head light
Old May 23, 2022 | 11:06 AM
hmart55's Avatar
hmart55
Default head light
Just replaced the head light gears and bulbs. Worked fine after replacement. Suddenly one head light went out. Checked all wiring and it is fine. Does each headlight have its own fuse?
Old May 24, 2022 | 07:43 AM
jmeyer58's Avatar
jmeyer58
I’m guessing the bulb is burned out, probably just a coincidence. Did you check for voltage at the plug? If no voltage here is a wiring diagram from a 96
File Type: pdf
