88 Chevy Corvette
Old Jun 8, 2022 | 10:02 PM
hotwheels69's Avatar
hotwheels69
2nd Gear
Default 88 Chevy Corvette
When I test the battery voltage says 12.3 voltage goes up to 13 when I start the car when i put it in reverse it goes to 12.3 when I drive it it goes up to 12.9 I tested the alternator the alternator is between 14.5 to 14.6 can the battery be bad. Plus the RPMs goes up and down a check for vacuum leaks don't have no vacuum leaks gave it a full tune up change the air control valve and the mass air flow also change the throttle position sensor and put a BBK throttle body 58 mil. Throttle position sensor is set at .54 anybody has any ideas what could be the problem.
Old Jun 9, 2022 | 07:14 AM
Incorvettei's Avatar
Incorvettei
I guess it is possible that the battery is bad. Following to see what the solution might be
