Anyone have CCW classics?
Old Jun 12, 2022 | 05:03 PM
Armybyrd21's Avatar
Armybyrd21
Default Anyone have CCW classics?
On an early C4? Planning on these but not sure what sizes for my ‘88.
Old Jun 13, 2022 | 01:51 PM
MatthewMiller's Avatar
MatthewMiller
I had CCW Classics on my 96 (I have since sold the car and the wheels went with it). But I'm not sure what the brand/model of wheel has to do with the wheel dimensions you need. An 88 came with 17x9.5 wheels with 56mm offset, so that's a start. The CCW specs in the pic you posted are wrong in multiple ways:
  • Not really the correct offset: these will sit 21mm further out that wheels with proper 56mm (or thereabouts) offset. These will probably fit because they're skinny, but they won't really be correct.
  • These are an inch narrower than stock and you should not try to pinch the stock tire size (275/40/17) onto them.
  • All C4s also have a 5x120.65 (5x4-3/4") bolt pattern, not the 5x120 that's showing in the picture you included (and yes, it matters).
If I were you, I'd look for something at 18x10 or 18x10.5 with offset between 50-56mm, and mount 285/35/18 tires on them. It needs the correct bolt pattern and a center bore of at least 70.3mm.
Old Jun 13, 2022 | 10:50 PM
Armybyrd21's Avatar
Armybyrd21
pic was just to show the wheels. Any pics of your old car?
Old Jun 14, 2022 | 12:45 AM
MatthewMiller
These were 17x11.5 CCWs with 315/35/17 race tires installed. Overkill for your needs, but they looked good.
To Anyone have CCW classics?
