Heat/AC adjustable vents - Remove?
Old Jun 15, 2022 | 04:10 PM
controlu's Avatar
controlu
Default Heat/AC adjustable vents - Remove?
1987 C4 Coupe (and others I'm sure.) Those adjustable/rotating/slated vents that aim the air coming out of the vents in the dash, are those removable without breaking things? If a slat is broken do you have to replace the whole dash part? I searched youtube but all I get is removing the heater core etc.
Old Jun 15, 2022 | 05:00 PM
RWDsmoke's Avatar
RWDsmoke
If you are talking about these vents they are cheap on ebay
They are held in by the retainers and easy to snap in and out from the back.
Old Jun 15, 2022 | 06:39 PM
controlu's Avatar
controlu
I shall do a closer inspection. Musta missed that.
Old Jun 15, 2022 | 11:08 PM
controlu's Avatar
controlu
Upon further inspection, CLOSE inspection, I find that you are totally correct, RWDsmoke. Thank you so very much. I never would have seen that without your direction.
Old Jun 17, 2022 | 11:41 AM
RWDsmoke's Avatar
RWDsmoke
If you look at the vents from the back you will see part of the area is blocked. I opened them up with a dremel and have much better air flow.
Old Jun 17, 2022 | 01:58 PM
controlu's Avatar
controlu
I see that. A good 50% of the vent is blocked. Thanks again for your help.
To Heat/AC adjustable vents - Remove?
