Touch up paint
Old Jun 17, 2022 | 12:54 PM
jimb63's Avatar
jimb63
3rd Gear
Default Touch up paint
Can anyone recommend a good source for touch up paint in spray cans. Paint Code WA8743
Old Jun 17, 2022 | 01:28 PM
hawk454's Avatar
hawk454
I prefer Eastwood 2k aerosol but went with Spray Max 2k recently and had great results on large touchup of roof, a/b pillars where clear coat was flaking.
ALL IN ONE:
https://repaintsupply.com/gm-wa8743-...hire-metallic/
Touch up kit comes with Primer, Color, and Clear-Coat. Although, I used aerosol base and 2k glamour clear coat because I had to sand off peeling clear coat so had a large area to blend into rest of vehicle.
Do not forget tack cloth, surface prep degreaser, and masking paper. Scuffing pad for blending 800 to 1500 range worked well for me depending on depth of re-finish. Use as wet sanding. Good Luck.
Old Jun 18, 2022 | 05:23 AM
rhandle's Avatar
rhandle
Default clear coat
ALL IN ONE:
For the flaking clear coat.did you sand then spray color and then clear? Or , do you sand the flaking clear and go directly to spraying clear over it? How does it look? I have the same problem on my hood so the whole hood needs to be done. I dont want to F it up.
Old Jun 18, 2022 | 11:13 AM
jrobin1's Avatar
jrobin1
The folks at Automotive Touchup do a really good job at supplying the correct paint. I bought Ruby Red Metallic from the for mine and it worked out great.
Exact-Match Car Paint | Premium Automotive Paint for Flawless Results | Easy-to-Use Auto Paint | Truck and Car Touch-Up Paint | AutomotiveTouchup
As recommended, be sure to use the 2k Spraymax clear coat SprayMax 2K Urethane Clearcoat
P.S. Watch a lot of youtube vids on topic for great help
To Touch up paint
