Help Replacing Antenna Mast
Old Jan 3, 2003 | 06:19 PM
RedWhiteandBlue's Avatar
RedWhiteandBlue
Default Help Replacing Antenna Mast
Trying to replace antenna mast on '90 coupe. Took old one out, removed broken piece from inside the spool, but when we tried to feed the new one in, it takes about 8 inches and then just stops! Grrr... the motor continues running and turning the radio off will eject the 8 inches. Don't know what's wrong. Any ideas :confused:
Thanx!
Old Jan 3, 2003 | 08:17 PM
hngacurv's Avatar
hngacurv
Default Re: Help Replacing Antenna Mast (RedWhiteandBlue)
Did you take the motor apart and hook the new mast in manually or are you trying to get it to lock itself in? I took mine apart and hooked it in with the antenna all the way down and then when everything was put back together and wired up it worked great.
Old Jan 3, 2003 | 10:10 PM
RedWhiteandBlue
Default Re: Help Replacing Antenna Mast (castivers)
Thanks for the response....we got it figured out. The plastic retainer underneath the spool was not seated all the way, which provided a stop for the mast when it tried to feed itself in. Fixed, done, yeah!
Old Jan 4, 2003 | 02:26 AM
vettl83's Avatar
vettl83
If I remember right when I did mine it only fed in about 8 inches too. The kicker was to make sure the cleats " for lack of a better term," had to be facing the outboard side of the car. Pushed it in until it stopped, turned the radio off and it sucked the rest of the cable down into the antenna motor. Thats the one thing I remember from the instuctions, was to pay attention to which direction the cleats were facing when removing the old mast. 84 CF 91 ZR-1
Old Jan 4, 2003 | 07:18 AM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Fixed, done, yeah!
:thumbs:
Old Jan 5, 2003 | 12:45 AM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
Default Re: Help Replacing Antenna Mast (Alchemist)
I just replaced the mast in my antenna yesterday and that's what I said too. :D
To Help Replacing Antenna Mast
