accidental acceleration
Old Jun 29, 2022 | 03:39 PM
george hodge's Avatar
george hodge
1st Gear
Default accidental acceleration
I am new to the forum. I started my '87 Corvette and it ran fine while I opened the shop door. When I put it in reverse it accelerated to max rpm and flew backward. I tried to hit neutral but caught drive and it sped forward slamming into a large piece of farm equipment, doing considerable damage to both. I saw a discussion posted in 2003 about unintended rapid acceleration blaming the control module. Has anyone else experienced this. I am looking for answers for the insurance adjuster. Considerable damage to the car, it went under a cotton picker.
Old Jun 29, 2022 | 05:13 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
it works via a cable, something needs to move the cable.
Old Jun 29, 2022 | 06:14 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
your car has brakes?
Old Jun 29, 2022 | 07:46 PM
FAUEE's Avatar
FAUEE
Every time I've ever seen or heard of this. The root cause was a driver (usually old or teenage) using the gas pedal and not the brake pedal.
As the others said, the throttle body on these is mechanical, driven by the pedal. If it was idling normal, you can rule a stuck cable out, as your idle rpm would have been maxed out. It was your foot on the gas, sorry to say. The important part is you're OK, and nobody was hurt.
Old Jun 29, 2022 | 10:04 PM
DWAVette's Avatar
DWAVette
Question, if an IAC was ordered to open to the max and the injectors were ordered to flow max, and the throttle body remained closed, would the air/fuel mix be close enough to run the engine?
Old Jun 30, 2022 | 06:31 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Examine the cruise control mechanism. In fact the entire throttle mechanism.
We had a Ford Taurus that would go into a run-away acceleration intermittently. The computer knew nothing about it. Luckily we were friends with the mechanic at the Ford dealership and he went the extra mile looking for the problem (my wife treated his father while he was in the hospital, which helped, that is how we met him), it turned out that a little plastic clip in the mechanism had broken which allowed the cable to come out of the "spot" and float. It didn't do it all the time, but when it did, the engine would go to full throttle.
There were other issues of this, and when I reported it, the NTSB actually contacted me to hear what the cause was.
You are looking for something that allows the throttle to open on its own. Go through the entire linkage.
or allows the cable/mechanism to move due to breakage, so yes !
Old Jun 30, 2022 | 10:21 AM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Does not take much to total these cars these days.
Old Jun 30, 2022 | 05:03 PM
drcook's Avatar
drcook
Not always. As I said above, there was an issue with Ford Taurus cars where a 25 cent plastic clip broke and allowed one of the cables in the cruise control mechanism to float up out of where it should have been and the car would go into a runaway.
Luckily it happened while I was driving and not my wife or daughter (she had just gotten her license). Neither would have thought fast enough to slam to neutral and turn the car off. It was instant full on acceleration.
Old Jun 30, 2022 | 05:05 PM
Railroadman
Originally Posted by ihatebarkingdogs
I don't think he's concerned about the damage to the car. It probably isn't insured for collision loss anyway.
He's concerned about having the damage to the farm machinery covered. I have no idea what kinds of coverage are offered for or normally put on farm implements. Probably comprehensive type coverage for things like theft, fire (the barn burning down on it), dropping into a sink hole in the field, that kind of stuff. Significant damage from the owner's personal car getting driven into it may not be considered covered under the policy (if any) on the cotton picker.
If the car is covered for Liability, then that is the coverage that would pay for repairs to the farm machinery.
So he needs to prove to the insurance company the car really DID accelerate on its own, and it wasn't something shady.
Hopefully they will see no weevil.
Old Jun 30, 2022 | 05:39 PM
ZumpC4's Avatar
ZumpC4
Old Jun 30, 2022 | 07:08 PM
car addict's Avatar
car addict
Good one
Old Jul 4, 2022 | 02:27 AM
slowc4vette's Avatar
slowc4vette
first thing im gonna say is these cars are extremely touchy on the throttle so it wouldnt surprise me if it was just an accidental push of the throttle. this may be a long shot but your throttle position sensor could be shot and read out the wrong input to the ECM causing the injectors to fire at max rpms. not sure if that would just stall the engine or not though if the throttle body was closed and not having air flow through. good luck getting it repaired though glad to hear your ok
Old Jul 5, 2022 | 11:54 AM
Railroadman
I suppose you already covered this, but any chance a floor mat or piece of carpet out of place got tangled up and activated the gas pedal?
To accidental acceleration
