C4 Shift Console for Automatic
Old Jul 21, 2022 | 02:14 PM
Radarluv's Avatar
Radarluv
6th Gear
Default C4 Shift Console for Automatic
Does anyone out there know the actual difference between a 1992-1993 Shift Console (part number 10152827) and a 1994-1996 Shift Console ( part number 10265546)?Not having luck finding the answer so I thought I would phone a friend ;-)
thx,
Radarluv
Old Jul 22, 2022 | 10:00 PM
C4 Steck's Avatar
C4 Steck
thx,
Radarluv
Looking at the photos of replacement consoles provided on corvette central for the 92-93 vs the 94-96, the later model appears to be wider on the right side from the cup holder to the right edge. Also the molded-in script (i don’t know what it says, I’d have to look on my car) to the rear of the indicator area is there on the 94-96 and not on the 92-93. This is based solely on these photos and not from my personal experience. Corvette central shows the 92-93 discontinued and the 94-96 available.
Old Aug 24, 2022 | 10:47 AM
Radarluv's Avatar
Radarluv
6th Gear
Thanks for the response...the 92-93 are about $150 if you can find one and the 94-96 are about $50 bucks. I was trying to cheap out but I guess I will have to bite the bullet.
Old Aug 24, 2022 | 02:54 PM
C4 Steck's Avatar
C4 Steck
Where have you seen the 94-96 for $50? I was going to go real cheap and refinish it for $20-25 for the SEM paint. If I can get a new reproduction or refurb for $50 I’d probably do that. Cheapest I’ve seen them is like $140-150.
Old Aug 24, 2022 | 03:25 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Easy to find, cost a bit more than that at some places,
https://www.ebay.com/itm/16549369111...3ABFBMoN3RlNpg
But less than that if you use mr google to look. They are in stock for $120.00 so might want to move on it if this is what you need.
https://www.zip-corvette.com/92-93-a...rim-plate.html
Old Aug 25, 2022 | 11:19 AM
Radarluv's Avatar
Radarluv
6th Gear
Search Google for "Black Rubber Automatic Shift Plate Console For 10265546 1994-1996 Corvette C4"...you will find New Old stock for $125 and up and aftermarket reproductions for $50 and up. Good luck!
Old Aug 25, 2022 | 03:50 PM
C4 Steck's Avatar
C4 Steck
Holy crap I can’t believe the options for these. I never found anything but repros for $150 before. It pays to have the right wording in the search. Thanks for the info and the OEM part number!
To C4 Shift Console for Automatic
