blown engine
Old Jul 22, 2022 | 09:08 PM
nhlighthouse's Avatar
nhlighthouse
Default blown engine
a blown engine or seized pistons....last Sunday out for a drive on Rte 93 in NH my 85 corvette started to overheat and then the oil pressure light came on. I was told by a mechanic that the engine is junk. Is it worth it to replace the engine? The body of the car is in GREAT condition. Would appreciate feedback in regards to this matter...PS I am sick to my stomach about my first Vette being wrecked Pease Help!
Old Jul 22, 2022 | 09:20 PM
cv67's Avatar
cv67
St. Jude Donor '05
Did he say why it overheated so the culprit can be fixed before the new one goes back in. Could be a lot of things..even a lousy fan relay
If you like the car of course throw an engine in it. Basic flat tappet 350 they are cheap and everywhere.
Gm still sells thier cheap crates, many other places.
Old Jul 22, 2022 | 09:39 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I would look for LS engine they are plug and run, lot of C4 owners are going that directions.
Old Jul 23, 2022 | 07:07 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
plug and run. this implies a simplicity to an ls swap.
that is misleading no?
Old Jul 23, 2022 | 09:29 PM
car addict's Avatar
car addict
I think so
Old Jul 23, 2022 | 11:04 PM
THE 383 admiral's Avatar
THE 383 admiral
Horrible. Sorry to hear that.
You mentioned overheat, oil warning light. And seized.
This indicates you had a oil problem. Did you notice low - no pressure. You could rebuild keeping the original engine matching the VIN. Keeping resell value.
Plenty of create options. I would grab the ZZ4 crate.
Best of luck.
Old Jul 24, 2022 | 11:41 PM
jv9999's Avatar
jv9999
Is an engine swap something you can handle? If not, paying someone else to do it may exceed the value of the car.
Old Jul 27, 2022 | 01:58 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
There are a lot of gaps in the story. OP says it overheated and oil pressure light came on. Not good. But then the diagnosis is either "a blown engine", (whatever THAT means), or seized piston. If a piston seized most likely you're not going anywhere. Did it shut down? Was it flatbedded to the "mechanic" or driven under its own power? I'm guessing this issue is a bit over OP's level (and maybe over that mechanic's level) and as v9999 says, buying a replacement and paying someone to put it in is going to be more than an '85 is worth. The first step is to find someone who knows what they are doing, and determine exactly what is going on. That is must-have info for OP to make an intelligent decision.
Old Jul 27, 2022 | 02:35 PM
cv67's Avatar
cv67
St. Jude Donor '05
x2 find out why first so that new engine doesnt overheat also. Could be a bad fan relay for all we know.
No ls swap is easy and cheap that is a myth. THere are guys with garages, lots of know hows and resources to do that themselves but every home done conversion 'cheap" ive seen is a complete hack job and usually dont hear much from them afterwards.
Tons of parts for 350s you can make plenty of power. If teens or low 20s isnt enough mpg then go buy a new accord.
Old Jul 27, 2022 | 02:55 PM
85WHITEZ51's Avatar
85WHITEZ51
Oh, where all the fun started for me. My engine gave up and that is when I grabbed my ZZ4, which then lead to TPIS headers and then later a mini ram which then led to the Dynamic EFI. Fun snowball of events :-)
Honestly, if you like the car and it's in good shape other than the engine now, just have a basic 350 crate longblock installed.
Old Jul 27, 2022 | 03:20 PM
Railroadman
Posts an agonized cry for help, then does not return for 5 days.
OP - there are people on here who can give you all the advice and help you need, but we need specifics to be able to help you. For example, I don't have much faith in a mechanic who just tells you the engine is blown. That description is like going to a doctor and telling him you're "sick". He or she is going to ask you a ton of questions like what kind of pain, where, when did it start, you get the idea. A "blown engine" could REALLY be anything from comparatively minor problems, to the thing being a total boat anchor. If you truly need and want help, we'll need more details to understand what's going on.
Not trying to be harsh - I know very well the sick feeling of something seriously wrong with MY Vette. Just trying to help you to help us to help you!
To blown engine
