'Jerking' while Accelerating - Need Help
Old Aug 2, 2022 | 01:16 AM
DelayedEnd's Avatar
DelayedEnd
Default 'Jerking' while Accelerating - Need Help
Hello,
I recently bought a 1986 Corvette (L98) with the 4+3 transmission. I have been experiencing an odd issue. Occasionally when I accelerate, the car will like jerk or hiccup, is almost seems like it is misfiring. It's a pretty distinct sound and you can feel it clearly while driving. I've experienced this in all gears at all speeds.
The issue 'seems' to be worse in overdrive but this might just be my imagination.
I would love any input that anyone has. I can provide more details if necessary. Thank you.
Popular Reply
Aug 2, 2022, 10:12 AM
Whaleman's Avatar
Whaleman
Seems kind of dangerous "jerking" while accelerating. Maybe better to pull off to the side. Dan
Old Aug 2, 2022 | 02:56 AM
tequilaboy's Avatar
tequilaboy
First thing would be to verify/check the timing with a timing light. Might be knocking and pulling timing due to knock retard. Also get a cable and log data to see what is going on.
Example products:
http://www.moates.net/aldu1-and-cabl....html?cPath=64
http://www.tunercat.com/DataCat/datacat.html
Old Aug 2, 2022 | 07:13 AM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
Agree^^^^^! First verify timing! Next question, how do the plugs, wires, cap and rotor look? You may have a bad spark plug or plug wiring grounding out. Would likely be worse in OD as the motor is more "lugging" (lower rpm's). If visually the ignition parts are old, I don't feel it's "throwing" parts at it, even if it doesn't solve your issue....a tune-up to the ignition system, done properly is usually beneficial! If timing is correct, my guess would be a plug wire melted or rubbed through the insulation.....Open the hood at night or in a dark garage while it's running and look around for arcing from a wire! Cap could be so bad that the spark intended for one cylinder is jumping to another. Tune it up! For good measure, throw in a fuel and air filter👍
Old Aug 2, 2022 | 10:02 AM
DelayedEnd's Avatar
DelayedEnd
Thanks for the replies! I'll have to check those things out.
Old Aug 2, 2022 | 10:12 AM
Whaleman's Avatar
Whaleman
Old Aug 2, 2022 | 11:14 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Originally Posted by DelayedEnd
Hello,
is jerking noticible when holding speed driving up steep hill?
Old Aug 2, 2022 | 12:33 PM
DelayedEnd's Avatar
DelayedEnd
I haven't gone up many steep hills but I haven't experienced that the times that I have.
Old Aug 2, 2022 | 12:35 PM
DelayedEnd's Avatar
DelayedEnd
Well, it doesn't really interfere with getting up to speed or anything. It more just doesn't 'feel' right, if that makes sense.
Old Aug 2, 2022 | 02:14 PM
Whaleman's Avatar
Whaleman
I have to agree it would not feel normal to me either. But I am 70 and not 18. Dan
Old Aug 2, 2022 | 04:22 PM
pedricd's Avatar
pedricd
Old Aug 2, 2022 | 04:39 PM
DelayedEnd's Avatar
DelayedEnd
I just realized what you meant haha.
Old Aug 2, 2022 | 08:47 PM
Whaleman's Avatar
Whaleman
When I saw your name I realized you would be going awful fast accelerating with your "DelayedEnd" playing into the equation. Dan
Old Aug 2, 2022 | 10:18 PM
Duc96cr's Avatar
Duc96cr
I started experiencing the same thing with my ‘86 L98, 4+3, yesterday. Mine was the overdrive engaging and disengaging on its own. Service Engine Soon light is on too, but that could be another issue. Once mine decided to stay out of overdrive the lurching quit. If that isn’t it with yours, try setting your timing a couple of degrees advanced and set your TPS voltage at the middle to top of the spec. This will give better off idle response but the Control unit will still limit maximum advance.
Old Aug 3, 2022 | 10:37 AM
SLVRSHRK's Avatar
SLVRSHRK
My vote is on a misfire as well. I had a similar issue that I chased on my 86 (automatic) for several months. I went as far as replacing the torque converter as I thought the lockup was non-functional. Same issues, seemed like it was only happening in overdrive at highway speeds.
For me, it turned out that the ignition wires on the passenger side got too close to the manifold and burnt some of the insulation, allowing any of the four plugs on that side to randomly misfire.
What I did notice is that after fixing the issue, at idle the engine does not move (shake) at all. Even though the miss was not felt in the lower gears, it was there even at idle, just barely noticeable.
Old Aug 3, 2022 | 06:36 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Have you taken the distributor cap loose and looked inside ? Back when I had cars with that kind of distributor, a buildup could occur on the electrodes causing firing issues. Also a cracked cap can cause an issue. Then there is a coil starting to go bad.
Do you know how long it has been since the car had an actual good tuneup with new wires, new cap, new plugs, etc ? It would be worth the investment to do so.
If you have a place where you can have it be really dark, run the car and look. You can see if there is any voltage leaking out from either a wire or the cap.
There is a reason different folks here have mentioned misfire as being a possible culprit.
Old Aug 3, 2022 | 10:29 PM
DelayedEnd's Avatar
DelayedEnd
Issue fixed!
So I took your suggestions and checked out the plugs and wires and one plug wire was loose. I snugged it back up and the car's running AMAZING! It's like a whole different car!! Thank you everyone for your suggestions.
To 'Jerking' while Accelerating - Need Help
