Reverse lights
Old Aug 17, 2022 | 02:35 PM
Edge2020's Avatar
Edge2020
4th Gear
Default Reverse lights
I have an 85 with the 4+3 trans. Recently had both slave and clutch master cylinder replaced. The reverse lights and the OD light in Info center do not work. Both worked prior to repair work. All fuse OK. Any ideas?
Old Aug 17, 2022 | 04:54 PM
LiveWire1's Avatar
LiveWire1
Check under the car on your transmission for the light switch wire connector and OD enabled connector being unplugged and hanging there. Back up lights are covered by a 15A fuse.
Old Aug 17, 2022 | 05:33 PM
Edge2020's Avatar
Edge2020
4th Gear
Checked that plug and the fuse, both OK Thx
Old Aug 17, 2022 | 05:34 PM
Edge2020's Avatar
Edge2020
4th Gear
Checked plug and fuse, both OK. Thx
Old Aug 17, 2022 | 05:35 PM
Edge2020's Avatar
Edge2020
4th Gear
Checked both plug and fuse. Both OK. Thx
Old Aug 17, 2022 | 09:00 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
When mine didnlt work, I adjusted the neutral safety.
But I don't have an '85, I have a '90 with an automatic.
But that's why mine weren't working, for whatever it might be worth.
To Reverse lights
