Sound Deadening
Old Aug 31, 2022 | 04:55 PM
Yonker's Avatar
Yonker
Default Sound Deadening
Ok. Just throwing this out there. Would Dynamat on the inside of the rear wheel wells make any difference?
Old Aug 31, 2022 | 05:49 PM
FostersPerformance's Avatar
FostersPerformance
Yes it will.
Old Aug 31, 2022 | 06:04 PM
vader86's Avatar
vader86
Yes they do make some difference, but if its exhaust resonance you're fighting, maybe not enough.
Old Aug 31, 2022 | 07:37 PM
Hawkeye56's Avatar
Hawkeye56
I actually installed the Dynamat extreme underneath my wheel wells last year and yes it did cut down on road noise.
Thanks Hawkeye56
Old Aug 31, 2022 | 08:24 PM
Yonker's Avatar
Yonker
Thanks everyone for the info. I think I will give it a try to get rid of road/tire noise.
Old Sep 1, 2022 | 09:19 PM
B.W.'s Avatar
B.W.
Let us know how it goes! Pics!
Old Sep 2, 2022 | 05:08 AM
rhandle's Avatar
rhandle
Default Underneath ?
Thanks Hawkeye56
Does underneath the wheel well mean on the outside surface?
Old Sep 2, 2022 | 08:50 AM
Hawkeye56's Avatar
Hawkeye56
I removed the rear wheel liners and installed Duramat on every surface I had access to.
Hawkeye56
Old Sep 14, 2022 | 09:06 AM
Joe C's Avatar
Joe C
did the complete inside of my 85 years ago. it's a tad more quiet, but the main thing, the car feels more solid. i bought 80 sq.ft. and used most all of it. For those that use sound deadener - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Sep 14, 2022 | 10:13 AM
jrobin1's Avatar
jrobin1
I put MLV (mass loaded vinyl) on the top side of my wheel well liners and it definitely made a difference. I cut small pieces, formed them to the liner with a heat gun and attached with small screws. The MLV sound blocker is pretty stiff and can be hard to work with.
This was in addition to putting 3 levels of sound blocking in the cabin. Front cabin-sound deadening squares, heat shield, MLV. Rear cabin-sound deadening squares, foam liner, MLV. On top of that, I replaced the carpeting. Cabin is much quieter and cooler. The A/C does not have to work near as hard.
Old Sep 14, 2022 | 10:44 AM
jrobin1's Avatar
jrobin1
Here are a couple of photos. The rear cabin with the 3 layers, plus carpet (sound deadener squares, foam pad, MLV) and the wheel well liner with MLV attached to top.
Old Sep 14, 2022 | 11:42 AM
detroitrust's Avatar
detroitrust
Over the top good work. What kind. of weight did you add? Amazed the carpet fit.
I'm putting my c4 up for sale.
Chris
Old Sep 14, 2022 | 12:23 PM
radar502's Avatar
radar502
Default What what I can’t here you
the sound off the road & tires vibrates the medial around the wheel wells that is were the bulk of the sound comes from so first have to kill the medial vibes just using the deader as a sound barrier will not get the full effects of the deadener first put the deadener on the medial then can put on other surfaces this is how is is designed to work have to deaden the vibes first
Old Sep 14, 2022 | 02:39 PM
jrobin1's Avatar
jrobin1
Chris, the carpet was touch and go in several places but I managed to get it in. I could not get the seat rail front caps on in the inside rails next to the trans hump. I don't know how much weight I added but the tradeoff of less heat and noise versus a little more performance was a good one for me. I did the work just before I took the car on my Route 66 road trip. It was worth all the work.
Are you listing the car on the forum? How much are you asking? I forgot, is it a manual or automatic?
Old Sep 14, 2022 | 03:37 PM
Cblock406's Avatar
Cblock406
Has anyone here tried one of the Blockit sound mats that lays down in the back? Sounds like they have good feedback on newer C generations
Old Sep 14, 2022 | 04:21 PM
B.W.'s Avatar
B.W.
Thanks for the pictures!
Old Sep 15, 2022 | 11:35 AM
jrobin1's Avatar
jrobin1
Pictures help. I forgot to mention that I also added a layer of Noico 80 mil sound deadener and a layer of MLV inside each door.
Old Sep 15, 2022 | 03:36 PM
car addict's Avatar
car addict
Yes. Have had for close to 3 years. I'm sure it's not as good a solution as ones that involve work, but it's all I need.
Old Sep 15, 2022 | 04:10 PM
TKO Performance's Avatar
TKO Performance
Premium Supporting Vendor
Active Streak: 90 Days
From: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
First, thank you for your purchase! Glad to hear your happy with the Blockit "Quick & Quiet". And you might be right,....It might not be as good as something that requires hours to install with all that permanent weight. But its pretty darn good for a 60 second install.
To Sound Deadening
