Ok guys just installed new water pump, ac delete, egr delete, new radiator hoses new 180 thermostat and coolant flush. When I started my csr up for the first time the temp jumped straight to 299. I know my car isn't overheating the fan switch is new and so is the temp sensor on the front of the intake. Car runs and idles fine just wondering why it's reading temp so high. Could I have possibly gotten a bad temp sensor?
Alright, I haven’t had an opportunity to work on cleaning the condenser but after. Bit of driving and more focused following of the temps I’ve noticed now that while cruising temps do gone to low 180s
(It’s a bit cool for San Antonio TX avg temps at around 55-65 degrees)
during idling it will go out to 220 and just hold steady there . . . Maybe the first day it still had some air in the system that it been finding its way out slowly maybe
now I feel more comfortable & confident in the car
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
