Headlight knob falls off
Old Sep 19, 2022 | 05:32 PM
pete315's Avatar
pete315
Default Headlight **** falls off
I removed the headlight switch **** to take off my dash bezel to get my cluster fixed. I just yanked off the **** without researching the proper way to remove the **** from the rod. Now when I put my **** back on, it doesn't lock onto the rod. The **** didn't crack and that metal tab piece is still inside the ****. Is there a small tab or notch that sticks out from the switch rod I could have broken off when I just yanked that **** off? I'm guessing that metal tab inside the **** might pass a small notch in the rod to lock it in place.
Old Sep 19, 2022 | 06:04 PM
JETS C3-C4's Avatar
JETS C3-C4
I think you will just have to bend that tab back into the correct position to grab onto the shaft.
Give that a try.
Old Sep 19, 2022 | 06:37 PM
Incorvettei's Avatar
Incorvettei
Try repositioning the tab in the **** or check to be sure the **** isn’t cracked
Old Sep 20, 2022 | 04:35 AM
Z51JEFF's Avatar
Z51JEFF
Next time you remove the **** press the small tab flat and the **** comes off.
To Headlight knob falls off
