Ive got a 1991 L98 that just died going down the road, i thought fuel pump at first, so i replaced the fuel pump then I replace the fuel relay turned out it wasn't the problem, so I checked and had no spark so I changed the distributor cap, rotor,and ICM and nothing's worked. what's next?
EFI basics.
Rule one check for codes verses wasted parts swaps.
A bad CTS can prevent starting.
This leaves fuse,
P.U. coil or ECU.
Check fuse. Test P.U. coil, Scan for codes.
