Egr delete? Headers
Old Oct 10, 2022 | 05:50 PM
CentralFL95C-4's Avatar
CentralFL95C-4
Default Egr delete? Headers
Any suggestions on egr delete headers for a 95 vert with manual 6?
any possible problems with the pcm?
Old Oct 10, 2022 | 07:29 PM
JD1964's Avatar
JD1964
You can turn off EGR in the tune pretty easy. You can even do it yourself if you're willing to get familiar with TunerPro and Flashhack and get the cable to connect the laptop usb to the OBD1 port on the car. Basically you use Flashhack to copy the PCM data to the laptop. Then you load the data into TunerPro and adjust it. Finally, use Flashhack to burn the new data back on to the PCM. This way the PCM wont set a trouble code when you delete the EGR stuff.
If you don't want to do it yourself, you can sent the PCM out and have it done.
Old Oct 10, 2022 | 11:17 PM
jv9999's Avatar
jv9999
Deleting the EGR only increases the chances of detonation. It doesn't help performance at all. I know, everyone does it anyway because it's a "pollution thing".
Old Oct 11, 2022 | 10:38 AM
Orion2011's Avatar
Orion2011
Just plug the hole in in the headers.
This is what worked on my 96 LT4 M22x1.5
https://smile.amazon.com/gp/product/...0?ie=UTF8&th=1
Old Oct 11, 2022 | 12:54 PM
vader86's Avatar
vader86
Engine won't care if the EGR is there or not, but the Code 32 will still set in the PCM. You would have to turn off the code in the tune.
To Egr delete? Headers
