C4 wire connector
Old Nov 8, 2022 | 08:34 AM
kingofdacoast's Avatar
kingofdacoast
Cruising
Default C4 wire connector
Anyone has any idea what this connector plugs into? It’s on top of the engine, at the rear near the distributor.
Old Nov 8, 2022 | 12:06 PM
Kevova's Avatar
Kevova
Looks like a oil gauge connector. There is a oil pressure T in the block under wiper motor.
Old Nov 8, 2022 | 12:45 PM
WVZR-1's Avatar
WVZR-1
Ang generally speaking the OP Gauge wire is actually TAN. Year wasn't mentioned so if car is 'modified' maybe there's a pillar gauge or something changed!
Old Nov 8, 2022 | 12:59 PM
kingofdacoast
Cruising
Its a 91.
Old Nov 10, 2022 | 11:41 AM
kingofdacoast
Cruising
I found it. Goes to the oil pressure switch which is mounted under the oil pressure sender. Couldn't even see the switch till I pulled some of the wiring out.
To C4 wire connector
