Vats
Old Dec 7, 2022 | 12:58 PM
Roger Fairchild's Avatar
Roger Fairchild
8th Gear
Default Vats
Where do I send my 92 ECU to get the vats disabled?
Old Dec 7, 2022 | 01:05 PM
WVZR-1's Avatar
WVZR-1
You only need the PROM 'modified' - you do NOT need to supply the entire ECM. If you've a good running C4 with that ECM you want to hang on to it. PROM only needs 'modified'!
Old Dec 7, 2022 | 04:43 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
There are ways to bypass VATS without messing with the prom/ecu. How well they work, I cannot say.
https://www.mamotorworks.com/corvett...p-modules-1521
https://www.volvette.com/4LK00L.html
To Vats
