Tire Flat Spot preventative
Old Dec 18, 2022 | 08:12 PM
maXjrC4's Avatar
maXjrC4
Default Tire Flat Spot preventative
Looks like cold weather is finally heading south. That means cold flat spots to me. I would like to get some ramps to help prevent tire flat spots. I have been looking at the Race Ramp flat spot stoppers 14”. What are you all using to prevent flat spots? If you are using the Race Ramp type, are you happy with them?
Old Dec 18, 2022 | 08:37 PM
Polo Vert's Avatar
Polo Vert
I raise the pressure to 40 psi. Works for me.
Old Dec 18, 2022 | 08:46 PM
car addict's Avatar
car addict
I second raising tire pressure. I personally do nothing about it.
Old Dec 18, 2022 | 08:56 PM
JD1964's Avatar
JD1964
In addition to increasing tire pressure, I move the car forward and backward various distances so it doesn’t sit on one spot too long
Old Dec 18, 2022 | 10:12 PM
C4 Steck's Avatar
C4 Steck
I recently had an issue with my Nittos flat spotting on me constantly. I bumped the pressure up to 37/35 front/ rear and it cured it immediately. Over the winter I’m likely going to get the car in a spot where I don't need to move it and pull the wheels. I have to do the brakes this winter anyway so it makes sense. I also looked into the race ramps as an option but they were a bit pricey for me but seem like a nice product. I was able to locate some much cheaper alternatives on the web that were definitely not as nice but looked like they would serve the same purpose.
Old Dec 18, 2022 | 10:58 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
As others have said, for winter I raise the pressure.
Old Dec 18, 2022 | 11:35 PM
SloJo's Avatar
SloJo
I jack mine up and put jack stands under it. It works great plus it lets air circulate under it. I also put glue traps by each wheel for mice. It spends 5 months in the air.
Old Dec 19, 2022 | 09:04 AM
maXjrC4's Avatar
maXjrC4
Thanks for the replies. I think I will keep my $300 for now and try raising the tire pressure. I am going to go from 30psi to 35psi.
Old Dec 19, 2022 | 11:20 AM
onchiota's Avatar
onchiota
put 5/8" blue or pink rigid insulation board under each tire and bump tire pressure up to 40 #.....works great !
Old Dec 20, 2022 | 12:42 PM
SouthernSon's Avatar
SouthernSon
I have those expensive cradles to help with the problem but the tires seem to adhere themselves to the material when parking while hot.
Old Dec 20, 2022 | 02:22 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I would buy from Home depot rubber mats, and cut them to size of tire, keeps it off the cold cement floor.
Old Dec 20, 2022 | 08:56 PM
JD1964's Avatar
JD1964
Check the max pressure listed on the tire sidewall. On my Nitto 555’s it’s 44psi. That’s where I take it to.
Im not sure from 30 to 35 is going to be all that different.
Old Dec 21, 2022 | 08:40 PM
buckybadger45's Avatar
buckybadger45
Exactly what I do. Move the car every 30 days or so, (without starting it). Tires, which are summer only, to about 42 lbs. Never had a problem.
Old Dec 22, 2022 | 10:09 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I put jack stands under the frame rails when I'm not driving the car. Started to do this after experiencing flat spots and before contoured anti-flatspotting pads were invented.
Not sure about overinflating. If you inflate enough to actually do much, the tires will probably be over their recommended maximum. To my way of thinking, going to 35 or 40 psi ....only 5-10 psi over normal operating pressure....isn't going to keep the tire 'round' with the weight of the car on them. But, I've been wrong before.
Old Dec 22, 2022 | 10:14 AM
rush0142's Avatar
rush0142
I've never had a problem with flat spots that 5 minutes of driving didn't fix.... If your Vette is up for the winter, just go out and start the car once every few weeks. And move the car forward or backwards a foot or two.
Old Dec 25, 2022 | 09:01 AM
Whaleman's Avatar
Whaleman
I just pumped my Continental Extreme Contact Sports up to 40 yesterday. I don't know if it really helps but the tire does look rounder. My compressor is right next to the car so it only takes a few minutes. Dan
Old Dec 25, 2022 | 10:00 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
This is the right idea. Are you in a position to pull the car in and out on a nice day? A full warm up and a 20ft pull in and out will do wonders.
To Tire Flat Spot preventative
Old Dec 30, 2022 | 06:40 PM
EVILOPTI's Avatar
EVILOPTI
2021 C4 of the Year - Modified Finalist
I usually drive my cars year round to prevent it but if one is going to be sitting for a long period I sit it on jack stands
Old Jan 3, 2023 | 05:16 PM
SouthernSon
I put those on the '96. Really bad about flat spotting while sitting even if only for a few days. Doesn't take too long to round out after a few miles. I may cobble up a form from wood one of these days. The store bought under the ZR1 is just too expensive for me to consider a second set.
Old Jan 3, 2023 | 06:15 PM
vader86's Avatar
vader86
Second on flat spotting Contis, mine would always flat spot after a few days. ECS or DWS, they just tend to spot a bit.
I had Conti DWS06s on my Cayenne, also flat spotted after 3 days. Thankfully it works out fast on the road.
