Fog Light/Tail Light interference
Old Dec 23, 2022 | 07:05 AM
90whiteoverblue's Avatar
90whiteoverblue
4th Gear
Default Fog Light/Tail Light interference
Hi All,I have a wiring issue that I am hoping maybe others have tackled with success.
When I put on my right turn signal - the outer right turn signal blinks the inner light is solid. When brakes are applied inner light - lights both brake and turn signal sections of the bulb. When fog lights are on it switches the symptom to the outside right rear light. So depending on if the fog lights are on or off determines which tail light functions properly.
I replaced all the turn signal bulbs and tail light bulbs and put in a new turn signal relay. I was thinking of replacing the fog lights, but it seems switch related. Any thoughts or experiences?
Vehicle is a 1990
Thank you all and Merry Christmas!
Old Dec 23, 2022 | 09:57 AM
Blue Bucket List's Avatar
Blue Bucket List
First thing I would do is check all of the grounds related to these lights. Sometimes bad grounds will cause feedback onto other circuits.
Old Dec 23, 2022 | 09:59 AM
FostersPerformance's Avatar
FostersPerformance
Did you have this issue before you replaced all those bulbs?
Old Dec 23, 2022 | 04:31 PM
90whiteoverblue
4th Gear
Yes, I changed all the bulbs to ensure that all the sockets had the correct bulbs - hoping that would fix it.
Old Dec 23, 2022 | 04:33 PM
90whiteoverblue
4th Gear
Negative on forgetting to mention. US spec. Correct when applying the turn signal both sections of the filament light. One light blinks correctly with the correct filament lighting. The other is solid on both filaments. When fog lights are turned on - the effected light switches to the inboard or outboard side.
Old Dec 23, 2022 | 08:06 PM
90whiteoverblue
4th Gear
Thanks I will research the rear ground straps. Much appreciated!
To Fog Light/Tail Light interference
