Water Wetter????
DarkHalo's numbers are close to what I've measured over the years on various vehicles.
6-8 degree temp drop on average, Water Wetter works by breaking the "surface tension" up, thus allowing the water to contact the cooling jackets/surfaces evenly.
A good way to visualize "Surface tension" is by looking at water on a freshly waxed surface VS an unwaxed surface...the water "beads up" on the waxed surface, so there is less water in contact with that surface.
The water on the unwaxed surface doesn't "bead" and thus lays out contacting more of the surface.
The more square inches of water in contact with a cooling jacket surface equates to more efficient heat removal from that surface.
:seeya
Larry :seeya
http://e30m3performance.com/myths/mo...ter_wetter.htm
We took a vacation in 2002, the temps were mid 90's with a heavily loaded van and the clutch still didn't engage. I'm glad even such a little temp difference in the coolant made the trip much more enjoyable. :)
Why were water treatments like WW produced? Because pure water cools much better then a 50% AF and 50% water mix, and racers wanted to take advantage of the cooling properties of water, w/o having to do a 50/50 AF mix.
Problem with pure water (although it cools much better), is that the engine will corrode, water provides no (or little) lubrication / protection for seals, and water tends to boil / steam on hot spots. Oh yeah, water freezes at 32*f, but racers don't give a rats butt about that.
So, a brew was mixed of normal anti-freeze components, to protect from corrosion, provide some lubrication and reduce localised boiling / steaming as best as possible. TA-DAH, "Watter Wetter", and any number of other brands of additive to provide this service.
So, if you want to run the most possible water in your system, an additive like WW will serve, and your engine will run cooler. However your water will freeze and crack your block. You also will be running on the bare minumum of protection in your cooling system, albeit perhaps adequate.
Now most of us want a little protection from temperatures below 32*, so we use a 50/50 mixture of AF and water. Do we want to add WW to this mix? Will it do anything? Well I think you can certainaly add it, but with a mixture of 50/50 and WW on top I would not expect any improvement, after all - you already reduced the water in the system. And, normal anti-freeze contains ALL THE ADDITIVES IN WATER WETTER!!!!
Yes that is right, normal ethelyne gylcol anti-freeze contains all these additives, plus prevents your coolant mixture from freezing. Yes the mix is a little different, but the additives do the same function. The wetting agent, in WW and AF is a compound similar to a basic - not sudsing - soap.
If you haven't figured it out at this point, my opinion is that using an additive like WW in a normal use engine is a waste of money.
Pete
Pete
The chemistry of "water wetter" does not support any significant temperature drop as an additive to 50/50 AF mix. "Water wetter", is a less able coolant as compared to pure water, excepting the wetting agents. A fresh mix of coolant is unlikely to benefit from additional wetting agents.
More likely, in all the above cases is other improvements in the cooling system. For example: fresh flush of coolant, improper AF /water mix to begin with, cleaner radiator, improvement in air flow through radiator through maintenance.
The above quote is a perfect example of how an additive gains support. The improvement has to do with real improvements in the cooling system, and little to do with any additive.
This arguement is also akin to the "I added a throttle body air foil, and can really feel a difference SOTP"
Pete
