Brake Lock Up!!
Old Feb 5, 2023 | 01:29 AM
cjrodgers's Avatar
cjrodgers
3rd Gear
Default Brake Lock Up!!
I’ve got a 94 that has brake problems. The front brakes lock up about 5-10 miles down the road after braking a few times. I’ve replaced calipers, brake pads, brake booster, brake hoses like people have suggested but nothing worked. I have ABS, ASR, BRAKE lights on. I’ve took it to several mechanics but none of them know what’s wrong with it!
Old Feb 5, 2023 | 09:48 AM
Purple92's Avatar
Purple92
Have you replaced the Master Cylinder ???
I'm assuming that if you crack a brake bleeder screw the impacted caliper releases.
I would try killing the power to the ABS system, and see if the issue "goes away".
Old Feb 5, 2023 | 10:27 AM
RWDsmoke's Avatar
RWDsmoke
Afer replacing the booster did you adjust the master cylinder push rod? The master cylinder push rod length is adjustable. If it is too long it won't allow the piston to return far enough to release all of the pressure after a little heat expansion. Easy way to check is loosen the two master cylinder bolts while the brakes are locked up. If that releases the pressure adjust the push rod lengtth.
Old Feb 6, 2023 | 10:22 AM
cjrodgers's Avatar
cjrodgers
3rd Gear
I have no replaced the master cylinder yet. I plan on doing so and how exactly do u kill the power to the abs. I have pulled the fuses to the abs before and it did nothing. is there another way or a step I missed?
Old Feb 6, 2023 | 10:24 AM
cjrodgers's Avatar
cjrodgers
3rd Gear
I have not. I’ll look at that. With the factory booster in, it still did all these symptom. Way before i ever put it in. It’s been doing on for a few years. The car sat for a while. I will check that though. Thank you!
Old Feb 6, 2023 | 05:03 PM
Purple92's Avatar
Purple92
The "best" way I know of to kill power to the ABS is to disconnect the wires going to it. The ABS module lives behind the driver seat - under that "storage area" cubby thing. Take out that plastic thing, and youi'll see the ABS pump - with numerous brake lines going to and from it. There are several multi-pin connectors that go to it. Disconnect those.
If disconnecting the ABS causes the problem to go away - the problem is in the ABS. If it doesn't go away - it's somewhere else in the brake hydraulic system.
To Brake Lock Up!!
