Cut wire under dash
Old Feb 28, 2023 | 08:23 AM
dwhipper61's Avatar
dwhipper61
Default Cut wire under dash
Hello, I was replacing the gauge cluster in my 89 convertible and found a pair of cut wires under the steering column. I'm assuming it would connect to the black wire I am also holding. The black wire appears to be a sheathing over a brown and a yellow wire. I have only had the car a few month and not noticed anything not working. What is this connection for? THANKS for any suggestions.
Old Feb 28, 2023 | 08:30 AM
WVZR-1's Avatar
WVZR-1
Brown & Yellow in that location are VATS and I'd say yours has been by-passed. You'll likely find a resistor of sorts under the tape.
Do you have the FSM (Factory Service Manual) for your car?
Old Feb 28, 2023 | 02:31 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Originally Posted by IHBD
The black wire isn't associated with VATS. Where does it go? Does it disappear into a factory loom, or is it stand-alone to something like an old stealth radar detector, or something?
He said “The black wire appears to be a sheathing over a brown and yellow wire.”. I wonder if it doesn’t run up the column to the ignition cylinder. It sure looks like VATS. I’m with Dave on this one.
Old Feb 28, 2023 | 02:54 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Ray is disagreeing but agreeing with me at the same time? Then I figured it out.
This made me laugh out loud! Thanks for the chuckle.
Old Feb 28, 2023 | 04:33 PM
dwhipper61's Avatar
dwhipper61
THANKS guys for the input......BTW....I'm Dave also.
Old Feb 28, 2023 | 04:37 PM
WVZR-1's Avatar
WVZR-1
Do you have the FSM?
Old Feb 28, 2023 | 07:15 PM
dwhipper61's Avatar
dwhipper61
I do not. I'm hoping to find one in Charlotte or Carlisle on my next trip.
To Cut wire under dash
