84 Initial Timing
Old Jan 13, 2003 | 11:10 PM
Magic Fingers's Avatar
Magic Fingers
Default 84 Initial Timing
Anyone know what the initial timing should be set at for a 84. The emissions lable is too worn to read. Thanks.
Old Jan 13, 2003 | 11:20 PM
polish41's Avatar
polish41
Default Re: 84 Initial Timing (Magic Fingers)
Timing is set at 6 degrees btdc. Don't forget to disconnect the single brown wire. It is near the fire wall. This will give you a true setting. :cheers:
