Dim Digital Speedometer
Old Mar 7, 2023 | 04:18 PM
wytamalan's Avatar
wytamalan
5th Gear
Default Dim Digital Speedometer
I've been browsing the forum for weeks trying to find a solution, but haven't found many answers. The digital speedometer on my 1996 is very dim, but still readable as long as it's not dark out. The numbers and letters are plenty clear. I've tried the flashlight + light sensor test, and it seems that the sensor does work, but the max brightness is extremely low. Everything else in the dash cluster is plenty bright when the dimmer is maxed out. Hoping for some suggestions before I take apart everything with no luck. Thanks!
Old Mar 7, 2023 | 05:13 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Go to WWW.Batee.com he has what you’ll need.
later,Tiny
Old Mar 7, 2023 | 08:14 PM
Kilobuck84's Avatar
Kilobuck84
If it's only the speedometer you've probably got some bulbs out.
X2 on Batee. Lots of good info on his site.
Old Mar 7, 2023 | 08:50 PM
Hawkeye56's Avatar
Hawkeye56
No worries call Batee
To Dim Digital Speedometer
