Idle Stumbling HELP
Old Mar 22, 2023 | 04:57 PM
SpinsTires's Avatar
SpinsTires
Cruising
Default Idle Stumbling HELP
Hey everybody, '88 L98 here (automatic) 51k Miles
I'm fighting a very rough idle that stumbles to a near stall 500 rpm then ramps up to 1200 rpm in a cycle 5 seconds high 5 seconds low.
Things I have done: New alt and serp belt (14.5V running)
Fuel pressure 39 psi at idle, ramps to 44 psi during the bogging phase of idle.
New IAC
TPS set to .538 volts (closest I could get to .54 lol)
Plugs are new
Cleaned MAF
Wires also new
Cap and rotor new
New EGR valve (OEM acdelco)
New battery
Cleaned all sensors with sensor cleaner.
all fuel injectors measure 15 ohms +/- 0.5 ohms
Repaired 2 vac hoses and inspected all others. (not to say there couldnt be something i missed but this idle is very "off" for a small vac leak
NO CODES. (EGR fixed my previous 32 code)
Thanks all for any input before i throw in the call and call a shop
Last edited by SpinsTires; Mar 22, 2023 at 04:57 PM. Reason: forgot to add mileage
Old Mar 22, 2023 | 08:00 PM
C4 Steck's Avatar
C4 Steck
O2 sensors? You’ve replaced many parts that could have contributed to it. Also check further for vacuum leaks. I know your car only has 51k on it, but the rubber vacuum hoses are 34 years old. I’m not super familiar with the procedure for checking them and common problem locations, but I’m sure some others can help you out with where and how to check.
Old Mar 23, 2023 | 02:01 AM
drive it's Avatar
drive it
The best way to figure it out is with live data off a scan tool. You can see if the O2 sensor is toggling etc. As for vacuum lines-the ones most missed for cracks run from the driver side under the headlight area to the engine.
Old Mar 23, 2023 | 09:48 AM
Weck86's Avatar
Weck86
Subscribing. I have same issue as OP. Mine is when the car is in gear (drive) at idle, it fluctuates between 500 (almost dies) and 700-750 rpm. Have done the exact same things as OP, no joy. I suspect vacuum leak somewhere? I think my next move will be to take to a shop and see if they can do a smoke test to hopefully find the leak. But monitoring this thread for other thoughts.
Old Mar 23, 2023 | 10:54 AM
SpinsTires's Avatar
SpinsTires
Cruising
I will replace o2 sensor and see if that helps. they are cheap enough that its easier to replace vs test plus the stock one is likely the one on the car from 88 lmao.
Will report back my findings.
Old Mar 23, 2023 | 11:12 AM
Talfryyn's Avatar
Talfryyn
I would replace the PCV valve. Then clean the inside of throttle body behind the throttle plates. Next do the base idle setting procedure.
Old Mar 23, 2023 | 12:32 PM
SpinsTires's Avatar
SpinsTires
Cruising
TB has been cleaned as well as base idle set 400 rpms all gaskets replaced with fel-pro
Old Mar 24, 2023 | 09:03 AM
SpinsTires's Avatar
SpinsTires
Cruising
Update, Installed a ACdelco PCV valve. the old one was a knock off and i noticed I could blow into either side and it wouldn't fully close off. test drive this morning on cold start was smoother ran fine 25 miles of city/highway.
Will update further to see if that was a fix or i just had 1 good startup
Old Mar 24, 2023 | 08:59 PM
ductape's Avatar
ductape
Cruise-In V Veteran
I had this same symptom on my '85 and tried a different MAF. Smoothed right out.
Old Mar 25, 2023 | 08:18 PM
SpinsTires's Avatar
SpinsTires
Cruising
Update: Did a cold start today (it was 70 degrees outside) car started like usual. bogged way down to 400 RPM right after startup and threatened to die. I didn't touch the gas and it went back to 800-1000 for the warmup normal phase before settling at 700 RPM.
SO: I'm still seeing an issue with the initial startup and the car choking then running relatively normal.
I have heard a faulty CTS in the block can be an issue with cold starts. I have a new one but tested the resistance on the old one and it checked out so I didn't want to drain coolant to change it
EDIT: wanted to add that warm starts or hot starts i DO NOT have this issue. it is only with COLD starts (engine temps)
Old Mar 25, 2023 | 09:05 PM
C4 Steck's Avatar
C4 Steck
Cold start injector? Not sure the 88’s have them? I did hear once 89-91 don’t? I know you said you had good fuel pressure, but maybe it’s not leaking down, just not functioning properly. Poor atomization, clogged? Also, I think the L98 had two CTS. Maybe research that and test the other if there is, in fact, another one. But the second might be for just the gauge and doesn’t send signal to ECM.
Old Apr 10, 2023 | 09:14 AM
SpinsTires's Avatar
SpinsTires
Cruising
Another update,
I replaced the coil, rotor and distributor cap (all were 1988 era) AS well as a new CTS, (the old one tested fine but wanted to rule out a sporatic one.) Tested all units prior to installing to verify working at various temps.
Also did a full smog delete. (no vaccum lines on a 1988 smog system) all plumbing removed/capped.
STILL when starting for first time car will start, idle for 2 seconds then stumble hard with a low idle that hunts up and down for about 5-7 minutes before smoothing out (closed loop im assuming by then)
Unplugged MAF when running and car dies.
To Idle Stumbling HELP
