88 programer vacuum
Old Mar 30, 2023 | 04:12 PM
Mitchl's Avatar
Mitchl
7th Gear
Default 88 programer vacuum
I suspect a vacuum leak on the supply side of my a/c programer can anyone tell me what's the best way to access the. unit
Old Mar 30, 2023 | 10:05 PM
Patsgarage's Avatar
Patsgarage
Pull out the drivers seat and have your chiropractor on speed dial.
Old Mar 30, 2023 | 10:55 PM
Mitchl's Avatar
Mitchl
7th Gear
Default 88 programer vacuum leak
Well ok it's a start I've got all other leaks repaired except that one line coming from the engine compartment one way valve I've isolated that one line I can't pull a vacuum on...ok the driver set is coming out
Old Mar 30, 2023 | 11:11 PM
Patsgarage's Avatar
Patsgarage
Pull the seat out, get some thick cardboard or padding to protect your back from the seat studs and it is not that bad of a job.
Old Mar 30, 2023 | 11:17 PM
Mitchl's Avatar
Mitchl
7th Gear
Thanks Pat I'm on it tomorrow morning
To 88 programer vacuum
