Paint code for 90
Old Jan 15, 2003 | 01:26 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Paint code for 90
Hi guys. I'm finally getting the license plate cover for my Forced Air intake painted and I'm using a "new guy" to paint it - the other is just too far away.
Anyway, this guy asked me for the paint code so he could match it (funny, the other guy matched it without the paint code....hmmm).
Where can I find out the paint code for my 90 with original paint?
Anyone know what it is? (I understand the red paint code changed around 93 BTW)
Old Jan 15, 2003 | 07:43 AM
HTRK-1's Avatar
HTRK-1
Default Re: Paint code for 90 (Red 90 L98 Coupe)
On my 93 it is inside the center console glove box, along with the other option codes. It should be designated with a "U" and "L". With your car being all red the two should be the same number (no two tone). Hope this helps.
Old Jan 15, 2003 | 07:51 AM
HTRK-1's Avatar
HTRK-1
I believe it should RPO 81, WA8774 for Bright red.
Old Jan 15, 2003 | 07:55 AM
baddmann's Avatar
baddmann
Default Re: Paint code for 90 (HTRK-1)
:iagree: You are correct, sir! :yesnod:
Old Jan 15, 2003 | 08:26 PM
The Dingo's Avatar
The Dingo
Default Re: Paint code for 90 (baddmann)
Thanks guys. :cheers:
I wasn't sure if the code under the console glove box door was the actual paint code or the GM option code for the paint. :bb
Thanks again. :)
To Paint code for 90
