1989 AC System
Old Apr 3, 2023 | 11:35 AM
BillDurant's Avatar
BillDurant
Default 1989 AC System
Any suggestions on what ac system to install in my car. It has major issues blows semi cool air and not great air flow. In Florida in summer 95 to 100 degrees months the car is just not drive-able.
I have my suspicions that even when new the ac in these things was never great in hot weather states, but I could be wrong.
Any thoughts?.
Old Apr 3, 2023 | 02:06 PM
topfuel67's Avatar
topfuel67
I got the factory ac working on my 89 convertible using R12. It worked great where I could drive it in 90-100 degree So Cal heat with the top down and ac on. It gave enough cold air that it was enjoyable to drive. At a stop light it felt great. People will argue that the 134 conversation works just as well. I disagree. R12 has lower cooling temps. I still find people selling 12 oz cans for $20 in the classified ads all the time.
Old Apr 3, 2023 | 03:42 PM
NavAir's Avatar
NavAir
On my '89, I converted to R134 about 15 years ago. Put in a new drier, orifice, O-rings, and oil. Cools great now, and I live in S. Texas.
Old Apr 3, 2023 | 04:58 PM
RWDsmoke's Avatar
RWDsmoke
I have an 86 but I converted to the 89 AC system because I like the later Denso compressor. I found that with R134a it is capable of reaching well below freezing, which turns the evaporator to a block of ice and stop air flow, if the cycle switch is not working correctly. If the system is properly evacuated, has the proper refrigerant oil, correct amout of refrigerant and cycle switch adjusted properly, it is very capable of cooling your Corvette. We had many 100 degree days in San Antonio last summer and mine worked fine.
Half of my center vents were blocked with plastic on the back side. I assume all early cars were the same. To increase air flow you can remove the center vents and dremel out the plastic to open them up. It made a big difference on my car.
Old Apr 3, 2023 | 11:33 PM
BillDurant's Avatar
BillDurant
Thanks to everyone
Old Apr 4, 2023 | 09:02 AM
BillDurant's Avatar
BillDurant
I'm not an ac guy or mechanic so probably will have to get someone locally to help
Old Apr 10, 2023 | 03:15 PM
vetman1's Avatar
vetman1
My '89 Coupe is still running on R-12 freon and blows 40° out of the dash vents. If you're car was mine, I would stay with R-12 for the simple fact of how good it works. The freon is easily available online. There are plenty of videos on how to evacuate and recharge the system as well as diagnostics to pinpoint any issues.
To 1989 AC System
