Still getting h22 code
Old Apr 13, 2023 | 03:40 PM
ThatOneNobody's Avatar
ThatOneNobody
Cruising
Default Still getting h22 code
So, I'm back again, I pulled code h22 so I checked the old tps and noticed it was bad, just changed the tps aaaaaaand I'm still getting the h22 code as well a constant stall every time I start the car, I'm just about at my wits end lol, any ideas?
Old Apr 13, 2023 | 07:38 PM
mothman52's Avatar
mothman52
What year is your bad boy?
Old Apr 13, 2023 | 07:55 PM
ThatOneNobody
Cruising
it's a 93 lt1
Old Apr 14, 2023 | 10:55 AM
mothman52's Avatar
mothman52
Is your TPS voltage low code showing any other codes related to your stalling issue? Cleaning the connector as IHBD suggested sounds like a good idea. Not to state the obvious, but any stalling issues need to be diagnosed as to either fuel or fire, and then go from there. Do you have any idea given your history with the car which is the more likely?
Old Apr 14, 2023 | 04:22 PM
ThatOneNobody
Cruising
So, i havent owned the car too long, when i bought it it was running pretty much perfectly till the head gasket blew, and after replacing the head gaskets, it started doing this issue with the stall, h22 is the only code it's throwing now, and about two-three days ago, I had it running almost perfectly for about 2 hours and all, till I got home and turned it off, then it went right back to the awful idle and stall, I just checked the voltage again and I'm not getting any voltage going to the tps now 🙃
Old Apr 15, 2023 | 12:30 PM
mothman52's Avatar
mothman52
Man, I wish I knew more Corvette-specific diagnostics. You say you blew the head gaskets. Those don't usually give way for no reason. Do you have any idea why?
I would say your idle problem is separate from your low/no voltage going to the TPS. I would think a related electrical problem with your crank sensor (for instance) giving you a rough idle would throw a code or two. Is your Opti nice and dry? I would pull a plug and see how they look. Probably one from the driver's side is the easiest to get to. You could see if they're getting gas at least or are fouled in some way. Easy things first. Wish I could be more helpful.
Keep us posted.
To Still getting h22 code
